Slicing UML-based Models of Real-time Embedded Systems, Int. Conf. Model Driven Engineering Languages and Systems, pp.346-356, 2018. ,
An Accessible Formal Specification of the UML and OCL Meta-Model in Isabelle/HOL, 2007. ,
UML2Alloy: A challenging model transformation, Int. Conf. Model Driven Engineering Languages and Systems, pp.436-450, 2007. ,
, On challenges of model transformation from UML to Alloy. Software & Systems Modeling, vol.9, pp.69-86, 2008.
Checking full satisfiability of conceptual models, Int. Work. Description Logics, p.55, 2010. ,
Component and Connector Views in Practice: An Experience Report, Int. Conf. Model Driven Engineering Languages and Systems, pp.167-177, 2017. ,
Testing Systems Specified as Partial Order Input/Output Automata, Testing of Software and Communicating Systems, pp.169-183, 2008. ,
An MDA framework supporting OCL, Electronic Communications of the EASST, vol.5, 2007. ,
HOL-OCL: A Formal Proof Environment for uml/ocl, Fundamental Approaches to Software Engineering, pp.97-100, 2008. ,
A Featurebased Survey of Model View Approaches. Software and Systems Modeling, vol.18, pp.1931-1952, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01891295
UMLtoCSP: a tool for the formal verification of UML/OCL models using constraint programming, Int. Conf. Automated Software Engineering, pp.547-548, 2007. ,
Finite Model Reasoning on UML Class Diagrams Via Constraint Programming, Artificial Intelligence and Human-Oriented Computing, pp.36-47, 2007. ,
Checking unsatisfiability for OCL constraints, Electronic Communications of the EASST, vol.24, 2010. ,
OCL2FOL+: Coping with Undefinedness, OCL@ MoDELS, vol.1092, pp.53-62, 2013. ,
OCL2MSFOL: a mapping to many-sorted first-order logic for efficiently checking the satisfiability of OCL constraints, Int. Conf. Model Driven Engineering Languages and Systems, pp.65-75, 2016. ,
Interface automata, SIGSOFT Software Engineering Notes, vol.26, pp.109-120, 2001. ,
A process algebraic view of input/output automata, Theoretical Computer Science, vol.138, pp.391-423, 1995. ,
, -J Meeting on the mathematical foundation of programing semantics
Contract-based modeling and verification of timed safety requirements within SysML. Software & Systems Modeling, vol.16, pp.587-624, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01567085
Automated Software Testing: Introduction, Management, and Performance, 1999. ,
The Architecture Analysis & Design Language (AADL): An Introduction, 2006. ,
A generalised theory of interface automata, component compatibility and error, Int. Conf. Integrated Formal Methods, pp.160-175, 2016. ,
Finite satisfiability of integrity constraints in object-oriented database schemas, Transactions on Knowledge and Data Engineering, vol.14, pp.123-139, 2002. ,
Satisfiability of object-oriented database constraints with set and bag attributes, Information Systems, vol.28, issue.3, pp.213-224, 2003. ,
Validating UML and OCL models in USE by automatic snapshot generation, Software & Systems Modeling, vol.4, pp.386-398, 2005. ,
USE: A UML-based specification environment for validating UML and OCL, Science of Computer Programming, vol.69, pp.27-34, 2007. ,
Proving and Visualizing OCL Invariant Independence by Automatically Generated Test Cases, pp.38-54, 2010. ,
EMFtoCSP: A tool for the lightweight verification of EMF models, Int. Work. Formal Methods in Software Engineering: Rigorous and Agile Approaches, pp.44-50, 2012. ,
Formal verification of static software models in MDE: A systematic review, Information and Software Technology, vol.56, pp.821-838, 2014. ,
Automation systems and integration -Object-Process Methodology, 2015. ,
Formal semantics of message sequence charts. Recommendation Z, p.120, 1998. ,
International Telecommunication Union ,
, Message Sequence Chart (MSC). Recommendation Z.120. International Telecommunication Union, 2011.
, Specification and Description Language -Overview of SDL-2010. Recommendation Z.100. International Telecommunication Union, 2019.
, The Theory of Timed I/O Automata, 2010.
Automatically deriving the specification of model editing operations from meta-models, Int. Conf. Theory and Practice of Model Transformations, pp.173-188, 2016. ,
From UML and OCL to relational logic and back, Int. Conf. Model Driven Engineering Languages and Systems, pp.415-431, 2012. ,
Modal I/O Automata for Interface and Product Line Theories, Programming Languages and Systems, pp.64-79, 2007. ,
Modeling requirements should be language agnostic! Example of a formal definition of simple Behavioral Decomposition Models, Int. Conf. Model-Driven Engineering and Software Development, pp.555-562, 2016. ,
On the satisfiability of dependency constraints in entity-relationship schemata, Information Systems, vol.15, pp.453-461, 1990. ,
An Introduction to Input/Output Automata, CWI Quaterly, vol.2, issue.3, pp.219-246, 1989. ,
Verifying component and connector models against crosscutting structural views, Int. Conf. Software Engineering, pp.95-105, 2014. ,
Efficient reasoning about finite satisfiability of UML class diagrams with constrained generalization sets, Eur. Conf. Model Driven Architecture-Foundations and Applications, pp.17-31, 2007. ,
Using B formal specifications for analysis and verification of UML/OCL models, Work. consistency problems in UML-based software development. Citeseer, pp.91-105, 2002. ,
OMG® Unified Modeling Language® (OMG UML®), 2017. ,
, OMG Systems Modeling Language (OMG SysML TM ). Standard. Object Management Group (OMG), 2019.
Incrementally slicing editable submodels, Int. Conf. Automated Software Engineering, pp.913-918, 2017. ,
OCL-Lite: Finite reasoning on UML/OCL conceptual schemas, Data & Knowledge Engineering, vol.73, pp.1-22, 2012. ,
AuRUS: Automated Reasoning on UML/OCL Schemas, Conceptual Modeling, 2010. ,
, , pp.438-444
Reasoning on UML Class Diagrams with OCL Constraints, pp.497-512, 2006. ,
Mapping from OCL/UML metamodel to PVS metamodel, Int. Symp. Information Technology. IEEE, 2008. ,
Automatic Generation of Consistency-Preserving Edit Operations for MDE Tools, Demos@MoDELS, 2014. ,
Mapping UML models incorporating OCL constraints into Object-Z. Imperial College of Science, Technology and Medicine, 2003. ,
MBSE with the ARCADIA Method and the Capella Tool, Eur. Cong. Embedded Real Time Software and Systems, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01258014
Providing explanations for database schema validation, Int. Conf. Database and Expert Systems Applications, pp.660-667, 2008. ,
Behavior-consistent specialization of object life cycles, Transactions on Software Engineering and Methodology, vol.11, pp.92-148, 2002. ,
Encoding OCL data types for SAT-based verification of UML/OCL models, Int. Conf. Tests and Proofs, pp.152-170, 2011. ,
Verifying UML/OCL models using Boolean satisfiability, Conf. Design, Automation and Test in Europe. European Design and Automation Association, pp.1341-1344, 2010. ,
Formal semantics and reasoning about uml class diagram, Int. Conf. Dependability of Computer Systems, pp.51-59, 2006. ,
Towards complete consistency checks of clafer models, In Int. Work. Feature-Oriented Software Development. ACM, pp.11-20, 2017. ,
Mathematical Programming for Anomaly Analysis of Clafer Models, Int. Conf. Model Driven Engineering Languages and Systems, pp.34-44, 2018. ,
Debugging of inconsistent UML/OCL models, Conf. Design, Automation and Test in Europe. EDA Consortium, pp.1078-1083, 2012. ,
Finding achievable features and constraint conflicts for inconsistent metamodels, Eur. Conf. Modelling Foundations and Applications, pp.179-196, 2017. ,
MaxUSE: a tool for finding achievable constraints and conflicts for inconsistent UML class diagrams, Int. Conf. Integrated Formal Methods, pp.348-356, 2017. ,
Compositional Reasoning for Shared-Variable Concurrent Programs, Int. Symp. Formal Methods, pp.523-541, 2018. ,
