Parallel Approaches in Multiple Sequence Alignments, International Journal of Advanced Research in Computer Science and Software Engineering, vol.4, issue.2, 2014. ,
A faster algorithm computing string edit distances, Journal of Computer and System sciences, vol.20, issue.1, pp.90002-90003, 1980. ,
A Succinct Four Russians Speedup for Edit Distance Computation and One-against-many Banded Alignment, Annual Symposium on Combinatorial Pattern Matching (CPM 2018), pp.1-12, 2018. ,
Efficient parallel algorithms for string editing and related problems, SIAM Journal on Computing, vol.19, issue.5, pp.968-988, 1990. ,
Parallel Dynamic Programming for Solving the String Editing Problem on a CGM/BSP, Proceedings of the fourteenth annual ACM symposium on Parallel algorithms and architectures, pp.275-281, 2002. ,
A space-efficient alphabet-independent Four-Russians' lookup table and a multithreaded Four-Russians' edit distance algorithm, Theoretical Computer Science, vol.656, pp.173-179, 2016. ,
Solutions parallèles efficaces sur le modèle CGM d'une classe de problèmes issus de la programmation dynamique, 2014. ,
Une nouvelle heuristique pour l'alignement de motifs 2D par programmation dynamique, Journées Francophones de Planification, Décision et Apprentissage pour la conduite de systèmess, pp.83-92, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00452916
On economical construction of the transitive closure of an oriented graph, Doklady Akademii Nauk, vol.194, issue.3, pp.487-488, 1970. ,
A subquadratic sequence alignment algorithm for unrestricted scoring matrices, SIAM journal on computing, vol.32, issue.6, pp.1654-1673, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00619573
Edit distance cannot be computed in strongly subquadratic time (unless SETH is false), Proceedings of the forty-seventh annual ACM symposium on Theory of computing, pp.51-58, 2015. ,
All shortest paths in weighted grid graphs and its application to finding all approximate repeats in strings, Proceedings Third Israel Symposium on the Theory of Computing and Systems, pp.67-77, 1995. ,
Geometric applications of a matrix-searching algorithm, Algorithmica, vol.2, issue.1-4, pp.195-208, 1987. ,
