HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
An Optimal Model for Optimizing the Placement and Parallelism of Data Stream Processing Applications on Cloud-Edge Computing
Abstract : The Internet of Things has enabled many application scenarios where a large number of connected devices generate unbounded streams of data, often processed by data stream processing frameworks deployed in the cloud. Edge computing enables offloading processing from the cloud and placing it close to where the data is generated, thereby reducing the time to process data events and deployment costs. However, edge resources are more computationally constrained than their cloud counterparts, raising two interrelated issues, namely deciding on the parallelism of processing tasks (a.k.a. operators) and their mapping onto available resources. In this work, we formulate the scenario of operator placement and parallelism as an optimal mixed-integer linear programming problem. The proposed model is termed as Cloud-Edge data Stream Placement (CESP). Experimental results using discrete-event simulation demonstrate that CESP can achieve an end-to-end latency at least 80% and monetary costs at least 30% better than traditional cloud deployment.
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-02926459
Contributor : Felipe Rodrigo de Souza Connect in order to contact the contributor
Submitted on : Monday, August 31, 2020 - 5:43:49 PM
Last modification on : Thursday, May 12, 2022 - 5:08:02 PM
Long-term archiving on: : Tuesday, December 1, 2020 - 12:58:19 PM
File
sbac-pad_2020.pdf
Identifiers
  • HAL Id : hal-02926459, version 1
Collections
Citation
Felipe Rodrigo de Souza, Marcos Dias de Assuncao, Eddy Caron, Alexandre da Silva Veith. An Optimal Model for Optimizing the Placement and Parallelism of Data Stream Processing Applications on Cloud-Edge Computing. SBAC-PAD 2020 - IEEE 32nd International Symposium on Computer Architecture and High Performance Computing, Sep 2020, Porto, Portugal. ⟨hal-02926459⟩
Share
Metrics
Record views
98
Files downloads
214
