Constructing Levels in Arrangements and Higher Order Voronoi Diagrams, SIAM J. Comput, vol.27, pp.654-667, 1998. ,
New algebraic conditions for the identification of the relative position of two coplanar ellipses, Computer Aided Geometric Design, vol.54, pp.35-48, 2017. ,
, Computational geometry: Algorithms and Applications, 2013.
Quadratic forms and their classification by means of invariant-factors, Cambridge tracts in mathematics and mathematical physics, vol.3, 1960. ,
Efficient Collision Detection Using a Dual Bounding Volume Hierarchy, Advances in Geometric Modeling and Processing, pp.143-154, 2008. ,
Collision Detection for Ellipsoids and Other Quadrics. Ph.D. Dissertation. The University of Hong Kong, 2008. ,
Continuous Collision Detection for Ellipsoids, IEEE Transactions on Visualization and Computer Graphics, vol.15, pp.311-325, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00646511
Continuous Collision Detection for Two Moving Elliptic Disks, IEEE Transactions on Robotics, vol.22, issue.2, pp.213-224, 2006. ,
Hyperpane Arrangements -An Introduction, 2017. ,
Nearoptimal parameterization of the intersection of quadrics: I. The generic algorithm, Journal of Symbolic Computation, vol.43, pp.168-191, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00071229
Near-optimal parameterization of the intersection of quadrics: II. A classification of pencils, Journal of Symbolic Computation, vol.43, pp.192-215, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00071228
Near-optimal parameterization of the intersection of quadrics: III. Parameterizing singular intersections, Journal of Symbolic Computation, vol.43, pp.216-232, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00071227
3D Game Engine Design, 2001. ,
A new approach to characterizing the relative position of two ellipses depending on one parameter, Computer Aided Geometric Design, vol.23, pp.324-350, 2006. ,
Automatic parsing of degenerate quadric-surface intersections, ACM Transactions on Graphics, vol.8, pp.174-203, 1989. ,
Random generation of periodic hard ellipsoids based on molecular dynamics: A computationallyefficient algorithm, J. Comput. Phys, vol.253, pp.471-490, 2004. ,
A benchmark study on accuracy-controlled distance calculation between superellipsoid and superovoid contact geometries. Mechanism and Machine Theory, vol.115, pp.77-96, 2017. ,
OBBTree: A hierarchical structure for rapid interference detection, Proceedings of Siggraph, pp.171-180, 1996. ,
, Arrangements. Handbook of Discrete & Computational Geometry, vol.21, pp.389-412, 2004.
A Perturbation Scheme for Spherical Arrangements with Application to Molecular Modeling, Computational Geometry, vol.10, pp.273-287, 1997. ,
Approximating polyhedra with spheres for timecritical collision detection, ACM Transactions on Graphics, vol.15, pp.179-210, 1996. ,
An algebraic approach to continuous collisiondetection for ellipsoids, Computer Aided Geometric Design, vol.28, pp.164-176, 2011. ,
A novel collision detection method based on enclosed ellipsoid, Proceedings of 2001 IEEE Conference on Robotics and Automation, pp.21-26, 2001. ,
Efficient collision detection using bounding volume hierarchies of k-DOPs, IEEE Transactions on Visualization & Computer Graphics, vol.4, pp.21-36, 2002. ,
Velocity obstacle based local collision avoidance for a holonomic elliptic robot, Autonomous Robots, vol.41, pp.1347-1363, 2017. ,
Mathematical models for determining the intersections of quadric surfaces, Comput. Graph. Image Process, vol.1, pp.73-87, 1979. ,
Motion Capture With Ellipsoidal Skeleton Using Multiple Depth Cameras, IEEE Transactions on Visualization & Computer Graphics PP, pp.1-1, 2016. ,
Ellipsoid-tree construction for solid objects, ACM Symposium on Solid and Physical Modeling, pp.303-308, 2007. ,
Variational 3D Shape Segmentation for Bounding Volume Computation, Computer Graphics Forum, pp.329-338, 2007. ,
Geometric Approaches to Nonplanar Quadric Surface Intersection Curves, ACM Transactions on Graphics, vol.6, pp.274-307, 1987. ,
Geometric Algorithms for Detecting and Calculating All Conic Sections in the Intersection of Any Two Natural Quadric Surfaces, CVGIP: Graphical Model and Image Processing, vol.57, pp.55-66, 1995. ,
V-Clip: Fast and Robust Polyhedral Collision Detection, ACM Transactions on Graphics, vol.17, issue.3, pp.177-208, 1998. ,
Collision Detection for Animation using Sphere-trees, Computer Graphics Forum, pp.105-116, 1995. ,
Obstacle collision detection using best ellipsoid fit, J. Intelligent Robotics Syst, vol.18, pp.105-126, 1977. ,
Granular gas of ellipsoids: analytical collision detection implemented on GPUs, Computational Particle Mechanics, vol.2, issue.2, pp.127-138, 2015. ,
Motion planning in stereotaxic radiosurgery, IEEE Transactions on Robotics and Automation, vol.9, pp.764-774, 1992. ,
On the lower degree intersections of two natural quadrics, ACM Transactions on Graphics, vol.13, pp.400-424, 2014. ,
Estimate of minimum distance between convex polyhedra based on enclosed ellipsoids, Proceedings of the IEEE/RST International Conference on Intelligent Robots and Systems, pp.739-744, 2000. ,
Fast and Exact Continuous Collision Detection with Bernstein Sign Classification, ACM Trans. Graph, vol.33, p.pages, 2014. ,
Using signature sequences to classify intersection curves of two quadrics, Computer Aided Geometric Design, vol.26, pp.317-335, 2009. ,
Defending Continuous Collision Detection Against Errors, ACM Transactions on Graphics, vol.33, issue.10, pp.1-122, 2014. ,
Modeling and Processing with Quadric Surfaces, Handbook of Computer Aided Geometric, pp.777-795, 2002. ,
Efficient Collision Detection for Moving Ellipsoids Using Separating Planes, Computing, vol.72, pp.235-246, 2004. ,
An algebraic condition for the separation of two ellipsoids, Computer Aided Geometric Design, vol.18, pp.531-539, 2001. ,
A method for modeling the damage behavior of concrete with a three-phase mesostructure, Construction and Building Materials, vol.102, pp.26-38, 2016. ,
Using signature Sequence to classify intersection curves of two quadrics, Computer Aided Geometric Design, vol.26, pp.317-335, 2009. ,
A canonical form for a pair of real symmetric matrices that generate a nonsingular pencil, Linear Algebra Appl, vol.14, pp.189-209, 1976. ,
The Equivalence of Non-Singular Pencils of Hermitian Matrices in an Arbitrary Field, American Journal of Mathematics, vol.57, pp.475-490, 1935. ,
