Field study of dispersion in a heterogeneous aquifer 2. Spatial moments analysis, Water Resources Res, vol.28, pp.3293-3307, 1992. ,
Stable determination of conductivity by boundary measurements, Appl. Anal, vol.2715372, 1988. ,
Determining 2-dimensional cracks in 3-dimensional bodies: uniqueness and stability Indiana Univ, Math. J, vol.46, p.181, 1997. ,
Identification of transient heat sources using the reciprocity gap, J. Inv. Ill-Posed Problems, vol.10, pp.588-599, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00732679
Identification of planar cracks by complete overdetermined data: inversion formulae, Inverse Problems, vol.12, pp.553-564, 1996. ,
Identification of pointwise sources and small size flaws via the reciprocity gap principle, 2006. ,
Fractional variational calculus in terms of Riesz fractional derivatives, J. Phys. A: Math. Theor, vol.40, p.6287, 2007. ,
Identification problems in potentiel theory, Arch. Rat. Mech. Anal, vol.101, pp.143-160, 1988. ,
Identification of Robin coefficient by the means of boundary measurements Inverse Problems, vol.15, p.142538, 1999. ,
On the identification of unknown boundaries submitted to Signorini boundary conditions: identifiability and stability Math, Methods Appl. Sci, vol.21, p.137998, 1998. ,
An inverse source problem in potential analysis. Inverse Problems, vol.16, pp.651-663, 2000. ,
Application to a pollution detection problem, Inverse. Ill Posed Problems, vol.10, pp.585-599, 2002. ,
Inverse source problem in an anisotropic medium by boundary measurements, Inverse Problems, vol.21, pp.1487-1506, 2005. ,
Determination of point wave sources by boundary measurements problem in potential analysis, Inverse Problems, vol.17, pp.1127-1139, 2001. ,
An inverse source problem for Helmholtz's equation from the Cauchy data with a single wave number, Inverse Problems, vol.27, issue.10, 2011. ,
Cauchy problem for fractional diffusion equations, Journal of Differential Equations, vol.199, pp.211-255, 2004. ,
Fractional diffusion equation and relaxation in complex viscoelastic materials, Phys. A, vol.191, pp.449-453, 1992. ,
, Partial differential equations, 1982.
Theory and Application of fractional differential equations, 2006. ,
Identification d'inclusions de petites tailles par des méthodes quasi-explicites: couplage RG-LSM, LAMSIN-ENIT, 2009. ,
Stability estimates for point sources identification problem using reciprocity gap concept via the Helmholtz equation, Applied Mathematical Modelling, vol.40, pp.7844-7861, 2016. ,
Boundary value problems for fractional diffusion equations, Phys. A, vol.278, pp.107-125, 2000. ,
Source terms identification for time fractional diffusion equation, Revista Colombiana de Matemás, vol.42, pp.25-46, 2008. ,
Overview to mathematical analysis for fractional diffusion equations-new mathematical aspects motivated by industrial collaboration, J Math Ind, vol.2, pp.99-108, 2010. ,
The realization of the generalized transfer equation in a medium with fractal geometry, Phys. Stat. Sol. B, vol.133, pp.425-430, 1986. ,
, Fractional Differential Equations. Mathematics in Science and Engineering, vol.198, 1999.
Inverse problem for fractional diffusion equation, Frac Calc Appl Anal, vol.14, pp.31-55, 2011. ,
Robin coefficient identification for a time-fractional diffusion equation, Inverse Problems in Science and Engineering, 2015. ,
An inverse time-dependent source problem for a time-fractional diffusion equation, Inverse Problems, vol.32, p.85003, 2016. ,
Inverse source problem for a fractional diffusion equation, Inverse Probl, p.27, 2011. ,
