Multirobot exploration of communicationrestricted environments: A survey, IEEE Intelligent Systems, vol.32, issue.6, pp.48-57, 2017. ,
Strategies for coordinated multirobot exploration with recurrent connectivity constraints, Autonomous Robots, vol.42, issue.4, pp.875-894, 2018. ,
Minpos: A novel frontier allocation algorithm for multi-robot exploration, International conference on intelligent robotics and applications, pp.496-508, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757960
Gradient convergence in gradient methods with errors, Journal on Optimization, vol.10, issue.3, 2000. ,
Collaborative visual area coverage using aerial agents equipped with ptz-cameras under localization uncertainty, 18th IEEE European Control Conference (ECC), pp.1079-1084, 2019. ,
Coordinated multi-robot exploration, IEEE Transactions on robotics, vol.21, issue.3, pp.376-386, 2005. ,
Coverage control for mobile sensing networks, IEEE Transactions on Robotics and Automation, vol.20, issue.2, pp.243-255, 2004. ,
A frontier-void-based approach for autonomous exploration in 3d, Advanced Robotics, vol.27, issue.6, pp.459-468, 2013. ,
Constrained centroidal Voronoi tessellations for surfaces, SIAM Journal on Scientific Computing, vol.24, issue.5, 2003. ,
Help from the sky: Leveraging uavs for disaster management, IEEE Pervasive Computing, vol.16, issue.1, pp.24-32, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01680461
Goal assignment using distance cost in multi-robot exploration, IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), pp.3741-3746, 2012. ,
Visual coverage control for teams of quadcopters via control barrier functions, IEEE International Conference on Robotics and Automation (ICRA), pp.3010-3016, 2019. ,
Command control for many-robot systems, Naval Command Control and Ocean Surveillance Center RDT and E Div, 1992. ,
Visibility-based multi-agent deployment in orthogonal environments, IEEE American Control Conference (ACC), 2007. ,
, Gazebo robot simulator
Octomap: An efficient probabilistic 3d mapping framework based on octrees, Autonomous Robots, vol.34, issue.3, pp.189-206, 2013. ,
Robust adaptive control. Courier Corporation, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01394197
Mobile robotics, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01236489
Probabilistic methods for centroidal Voronoi tessellations and their parallel implementations, Parallel Computing, vol.28, issue.10, 2002. ,
A comparison of path planning strategies for autonomous exploration and mapping of unknown environments, Autonomous Robots, vol.33, issue.4, pp.427-444, 2012. ,
Real-time adaptive multi-robot exploration with application to underwater map construction, Autonomous robots, vol.40, issue.6, pp.987-1015, 2016. ,
An adaptive optimization scheme with satisfactory transient performance, Automatica, vol.45, issue.3, 2009. ,
Least squares quantization in PCM, IEEE transactions on information theory, vol.28, issue.2, 1982. ,
Cooperative frontier-based exploration strategy for multi-robot system, 13th Annual Conference on System of Systems Engineering (SoSE), pp.203-210, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01867342
The true role of accelerometer feedback in quadrotor control, IEEE International Conference on Robotics and Automation, pp.1623-1629, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00422423
Spatial tessellations, 1992. ,
Collaborative visual area coverage, Robotics and Autonomous Systems, p.92, 2017. ,
Combining stochastic optimization and frontiers for aerial multi-robot exploration of 3d terrains, IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02164806
Multi-robot threedimensional coverage of unknown areas, The International Journal of Robotics Research, vol.31, issue.6, 2012. ,
Vision-controlled micro flying robots: from system design to autonomous navigation and mapping in GPS-denied environments, IEEE Robotics & Automation Magazine, vol.21, issue.3, 2014. ,
Stochastic optimization, Handbook of computational statistics, pp.173-201, 2012. ,
An autonomous exploration algorithm using environment-robot interacted traversability analysis, IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), pp.4885-4890, 2019. ,
On deployment of wireless sensors on 3d terrains to maximize sensing coverage by utilizing cat swarm optimization with wavelet transform, IEEE Trans. on Systems, Man, and Cybernetics, vol.44, issue.1, pp.111-120, 2014. ,
Distributed visibility-based coverage using a swarm of UAVs in known 3D-terrains, IEEE International Symposium on Communications, Control and Signal Processing, 2014. ,
Near-optimal probabilistic search via submodularity and sparse regression, Autonomous Robots, vol.41, issue.1, 2017. ,
A frontier-based approach for autonomous exploration, IEEE International Symposium on Computational Intelligence in Robotics and Automation, pp.146-151, 1997. ,
Frontier-based exploration using multiple robots, Proceedings of the second international conference on Autonomous agents, pp.47-53, 1998. ,
3d model-based multi-camera deployment: a recursive convex optimization approach, IEEE/ASME Transactions on Mechatronics, vol.20, issue.6, pp.3157-3169, 2015. ,
A 3d frontier-based exploration tool for mavs, IEEE 27th International Conference on Tools with Artificial Intelligence (ICTAI), pp.348-352, 2015. ,
