There is as yet Insufficient Data for a Meaningful Answer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Maria Boritchev
Maxime Amblard
Formal studies of discourse raise numerous interrogations on the nature and the definition of the way consecutive sentences combine with one another. The shift from discourse to dialogue brings forward even more specific issues. Dialogue acts are more intrinsically connected because of the dynamicity of the interaction. This article introduces a proof of concept of a formal compositional treatment of the relationship between consecutive utterances. Starting from neo-Davidsonian event semantics, we propose to use the relative response set as an intermediate set tool that allows us to define notions of question-answer correspondence, model the effect of clarification requests on previous utterances and compute semantic representations of dialogue interactions .
insufficient-data-boritchev-amblard.pdf (315.77 Ko) Télécharger le fichier
hal-02930715 , version 1 (04-09-2020)
  • HAL Id : hal-02930715 , version 1
Maria Boritchev, Maxime Amblard. There is as yet Insufficient Data for a Meaningful Answer. SemDial - WatchDial The 24th Workshop on the Semantics and Pragmatics of Dialogue, Jul 2020, Brandeis, United States. ⟨hal-02930715⟩
165 Consultations
239 Téléchargements
