Conference papers
Analysis of the Runtime Resource Provisioning of BPMN Processes using Maude
Abstract : Companies are continuously adjusting their resources to their needs following different strategies. However, the dynamic provisioning strategies are hard to compare. This paper proposes an automatic analysis technique to evaluate and compare the execution time and resource occupancy of a business process relative to a workload and a provisioning strategy. Such analysis is performed on models conforming to an extension of BPMN with quantitative information, including resource availability and constraints. Within this framework, the approach is fully mechanized using a formal and executable specification in the rewriting logic framework, which relies on existing techniques and tools for simulating probabilistic and real-time specifications.
Document type :
Conference papers
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-02931077
Contributor : Gwen Salaün Connect in order to contact the contributor
Submitted on : Friday, September 4, 2020 - 6:06:43 PM
Last modification on : Wednesday, July 6, 2022 - 4:22:49 AM
Long-term archiving on: : Wednesday, December 2, 2020 - 8:54:07 PM
File
main-11.pdf
Identifiers
  • HAL Id : hal-02931077, version 1
Citation
Francisco Duran, Camilo Rocha, Gwen Salaün. Analysis of the Runtime Resource Provisioning of BPMN Processes using Maude. WRLA 2020 - 13th International Workshop on Rewriting Logic and its Applications, Apr 2020, Dublin, Ireland. pp.1-16. ⟨hal-02931077⟩
Share
Metrics
Record views
72
Files downloads
104
