Generalizing the Edge-Finder Rule for the Cumulative Constraint, Proceedings of the 25th International Joint Conference on Artificial Intelligence (IJCAI 2016, pp.3103-3109, 2016. ,
Extending CHIP in order to solve complex scheduling and placement problems, Mathematical and Computer Modeling, vol.17, issue.7, pp.57-73, 1993. ,
URL : https://hal.archives-ouvertes.fr/hal-00442821
A Quadratic Edge-Finding Filtering Algorithm for Cumulative Resource Constraints, Constraints, vol.19, issue.3, pp.243-269, 2014. ,
Simple and Scalable Time-Table Filtering for the Cumulative Constraint, Proceedings of the 21st International Conference on Principles and Practice of Constraint Programming, pp.149-157, 2015. ,
A Cumulative Not-First/Not-Last Filtering Algorithm in O(n 2 log(n), Indian Journal of Pure Applied Mathematics, vol.44, issue.1, pp.95-115, 2013. ,
Constraint-based scheduling: applying constraint programming to scheduling problems, Kluwer, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00123562
, Computers and Intractability, vol.29, 2002.
A Quadratic Extended Edge-Finding Filtering Algorithm for Cumulative Resource Constraints, International Journal of Planning and Scheduling, vol.1, issue.4, pp.264-284, 2013. ,
Horizontally Elastic Not-First/Not-Last Filtering Algorithm For Cumulative Resource Constraint, LNCS, vol.10848, pp.316-332, 2018. ,
On linear lower bounds for the resource constrained project scheduling problem, European Journal of Operational Research, vol.149, issue.2, pp.314-324, 2003. ,
Event-based milp models for resource-constrained project scheduling problems, Computers & Operations Research, vol.38, pp.3-13, 2011. ,
Choco Solver Documentation, 2016. ,
A scalable sweep algorithm for cumulative constraint, Proceedings of the 18th International Conference on Principles and Practice of Constraint Programming, pp.439-454, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00754043
Conflict Ordering Search for Scheduling Problems, Proceedings of the 21st International Conference on Principles and Practice of Constraint Programming, pp.140-148, 2015. ,
