Determination of point-forces via extended boundary measurements using a game strategy approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we consider a game theory approach to deal with an inverse problem related to the Stokes system. The problem consists in detecting the unknown point-forces acting on the fluid from incomplete measurements on the boundary of a domain. The approach that we propose deals simultaneously with the reconstruction of the missing data and the determination of the unknown point-forces. The solution is interpreted in terms of Nash equilibrium between both problems. We develop a new point-force detection algorithm, and we present numerical results to illustrate the efficiency and robustness of the method.
CARI2020-25.pdf (845.13 Ko) Télécharger le fichier
hal-02931888 , version 1 (07-09-2020)
  • HAL Id : hal-02931888 , version 1
Marwa Ouni, Abderrahmane Habbal, Moez Kallel. Determination of point-forces via extended boundary measurements using a game strategy approach. CARI 2020 - Colloque Africain sur la Recherche en Informatique et en Mathématiques Appliquées, Oct 2020, Thiès, Senegal. ⟨hal-02931888⟩
156 Consultations
43 Téléchargements
