An Efficient Sequential Pattern Mining Algorithm Based on the 2-Sequence Matrix, Workshops Proceedings of the 8th IEEE International Conference on Data Mining (ICDM 2008), pp.583-591, 2008. ,
Mining Sequential Patterns by Pattern-Growth: The PrefixSpan Approach, IEEE Trans. Knowl. Data Eng, vol.16, issue.11, pp.1424-1440, 2004. ,
, Data Mining: Concepts and Techniques, 2000.
Mining Frequent Patterns without Candidate Generation, Proceedings of the 2000 ACM SIGMOD International Conference on Management of Data, pp.1-12, 2000. ,
Prism: An effective approach for frequent sequence mining via prime-block encoding, J. Comput. Syst. Sci, vol.276, issue.1, pp.88-102, 2010. ,
A pattern growthbased sequential pattern mining algorithm called prefixSuffixSpan, EAI Endorsed Trans. Scalable Information Systemsurnal, vol.4, p.4, 2017. ,
Contribution to the sequential and parallel discovery of sequential patterns with an application to the design of e-learning recommenders, 2018. ,
Indexed Bit Map (IBM) for Mining Frequent Sequences, Knowledge Discovery in Databases: PKDD 2005, 9th European Conference on Principles and Practice of Knowledge Discovery in Databases, pp.659-666, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00324633
TSPADE: An Efficient Algorithm for Mining Frequent Sequences, Machine Learning, vol.42, pp.31-60, 2001. ,
Parallel Sequence Mining on Shared-Memory Machines, J. Parallel Distrib. Comput, vol.61, issue.3, pp.401-426, 2001. ,
A taxonomy of sequential pattern mining algorithms, ACM Comput. Surv, vol.43, issue.1, 2010. ,
SPMF: a Java open-source pattern mining library, Journal of Machine Learning Research, vol.15, issue.1, pp.3389-3393, 2014. ,
, Proceedings of the Eleventh International Conference on Data Engineering, pp.3-14, 1995.
Density-based data partitioning strategy to approximate large-scale subgraph mining, Inf. Syst, vol.48, pp.213-223, 2015. ,
A samplingbased framework for parallel data mining, Proceedings of the ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, pp.255-265, 2005. ,
Parallel tree-projection-based sequence mining algorithms, Parallel Computing, vol.30, pp.443-472, 2004. ,
LAPIN: Effective Sequential Pattern Mining Algorithms by Last Position Induction for Dense Databases, Advances in Databases: Concepts, Systems and Applications, 12th International Conference on Database Systems for Advanced Applications, pp.1020-1023, 2007. ,
, EFFICIENT ALGORITHMS TO IDENTIFY PERIODIC PATTERNS IN MULTIPLE SEQUENCES, vol.489, pp.205-226, 2019.
An efficient algorithm for mining periodic high-utility sequential patterns, Appl. Intell, vol.48, pp.4694-4714, 2018. ,
Discovering Periodic-Correlated Patterns in Temporal Databases, T. Large-Scale Data-and Knowledge-Centered Systems, vol.38, pp.146-172, 2018. ,
