When Deep Learning Meets Digital Image Correlation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optics and Lasers in Engineering Année : 2021
Kamel Abdelouahab
  • Fonction : Auteur
François Berry
Benoît Blaysat
Michel Grediac
  • Fonction : Auteur
  • PersonId : 1038622
Convolutional Neural Networks (CNNs) constitute a class of Deep Learning models which have been used in the recent past to resolve many problems in computer vision, in particular optical flow estimation. Measuring displacement and strain fields can be regarded as a particular case of this problem. However, it seems that CNNs have never been used so far to perform such measurements. This work is aimed at implementing a CNN able to retrieve displacement and strain fields from pairs of reference and deformed images of a flat speckled surface, as Digital Image Correlation (DIC) does. This paper explains how a CNN called StrainNet can be developed to reach this goal, and how specific ground truth datasets are elaborated to train this CNN. The main result is that StrainNet successfully performs such measurements, and that it achieves competing results in terms of metrological performance and computing time. The conclusion is that CNNs like StrainNet offer a viable alternative to DIC, especially for real-time applications.
boukhtache_when.pdf (19.93 Mo) Télécharger le fichier
hal-02933431 , version 1 (08-09-2020)
Seyfeddine Boukhtache, Kamel Abdelouahab, François Berry, Benoît Blaysat, Michel Grediac, et al.. When Deep Learning Meets Digital Image Correlation. Optics and Lasers in Engineering, 2021, 136, pp.106308. ⟨10.1016/j.optlaseng.2020.106308⟩. ⟨hal-02933431⟩
1390 Consultations
213 Téléchargements
