Grammatical Evolution to Mine OWL Disjointness Axioms Involving Complex Concept Expressions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Discovering disjointness axioms is a very important task in ontology learning and knowledge base enrichment. To help overcome the knowledge-acquisition bottleneck, we propose a grammar-based genetic programming method for mining OWL class disjointness axioms from the Web of data. The effectiveness of the method is evaluated by sampling a large RDF dataset for training and testing the discovered axioms on the full dataset. First, we applied Grammatical Evolution to discover axioms based on a random sample of DBpedia, a large open knowledge graph consisting of billions of elementary assertions (RDF triples). Then, the discovered axioms are tested for accuracy on the whole DBpedia. We carried out experiments with different parameter settings and analyze output results as well as suggest extensions.
WCCI2020_camera_ready.pdf (627.54 Ko) Télécharger le fichier
hal-02936253 , version 1 (11-09-2020)
Thu Huong Nguyen, Andrea G. B. Tettamanzi. Grammatical Evolution to Mine OWL Disjointness Axioms Involving Complex Concept Expressions. CEC 2020 - IEEE Congress on Evolutionary Computation, Jul 2020, Glasgow, United Kingdom. pp.1-8, ⟨10.1109/CEC48606.2020.9185681⟩. ⟨hal-02936253⟩
124 Consultations
213 Téléchargements
