HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
Hardy-Hodge decomposition of vector fields on compact Lipschitz hypersurfaces
Abstract : For M a compact Lipschitz Riemannian manifold of dimension at least 2, we prove a Helmholtz-Hodge decomposition of tangent $L p$ vector fields as a sum of a gradient and a divergence free fields; the result holds for restricted range of p around 2, and for all $p ∈ (1, ∞)$ when M is V M O-smooth. If, moreover, M is a compact and connected hypersurface having the local Lipschitz graph property, embedded in $R n+1$ with the natural metric, we also establish a Hardy-Hodge decomposition of a $R n+1$-valued vector field of L p class on M as the sum of a tangent divergence free field and of two (traces of) harmonic gradients of Hardy class with exponent p, one from inside and one from outside M. The latter holds for restricted range of p, and for all $p ∈ (1, ∞)$ when M is $C 1$-smooth.
Document type :
Complete list of metadata
Cited literature [63 references]  Display  Hide  Download
https://hal.inria.fr/hal-02936934
Contributor : Laurent Baratchart Connect in order to contact the contributor
Submitted on : Friday, September 11, 2020 - 8:10:08 PM
Last modification on : Friday, February 4, 2022 - 3:08:55 AM
Long-term archiving on: : Friday, December 4, 2020 - 9:19:53 PM
File
BDQ11.pdf
Identifiers
  • HAL Id : hal-02936934, version 1
Collections
Citation
Laurent Baratchart, Dang Pei, Tao Qian. Hardy-Hodge decomposition of vector fields on compact Lipschitz hypersurfaces. 2020. ⟨hal-02936934⟩
Share
Metrics
Record views
60
Files downloads
142
