The pseudo-marginal approach for efficient monte carlo computations, The Annals of Statistics, vol.37, pp.697-725, 2009. ,
Convergence properties of pseudo-marginal markov chain monte carlo algorithms, The Annals of Applied Probability, vol.25, pp.1030-1077, 2015. ,
, Establishing some order amongst exact approximations of mcmcs, The Annals of Applied Probability, vol.26, pp.2661-2696, 2016.
Geometric mcmc for infinite-dimensional inverse problems, Journal of Computational Physics, pp.327-351, 2017. ,
Multilevel sequential monte carlo with dimensionindependent likelihood-informed proposals, SIAM/ASA Journal on Uncertainty Quantification, vol.6, pp.762-786, 2018. ,
A tensor approximation method based on ideal minimal residual formulations for the solution of high-dimensional problems, ESAIM: Mathematical Modelling and Numerical Analysis, vol.48, pp.1777-1806, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00861914
, Handbook of Markov Chain, 2011.
Markov chain monte carlo using an approximation, Journal of Computational and Graphical statistics, vol.14, pp.795-810, 2005. ,
Active subspace methods in theory and practice: applications to kriging surfaces, SIAM Journal on Scientific Computing, vol.36, pp.1500-1524, 2014. ,
Accelerating markov chain monte carlo with active subspaces, SIAM Journal on Scientific Computing, vol.38, pp.2779-2805, 2016. ,
Forward and backward uncertainty quantification with active subspaces: application to hypersonic flows around a cylinder, Journal of Computational Physics, p.109079, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-01592591
Multilevel dimension-independent likelihood-informed mcmc for large-scale inverse problems, 2019. ,
Dimension-independent likelihood-informed mcmc, Journal of Computational Physics, vol.304, pp.109-137, 2016. ,
Likelihood-informed dimension reduction for nonlinear inverse problems, Inverse Problems, vol.30, p.114015, 2014. ,
Theoretical guarantees for approximate sampling from smooth and log-concave densities, Journal of the Royal Statistical Society: Series B (Statistical Methodology), pp.651-676, 2017. ,
Sequential Monte Carlo samplers, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.68, pp.411-436, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01593880
Efficient implementation of markov chain monte carlo when using an unbiased likelihood estimator, Biometrika, vol.102, pp.295-313, 2015. ,
High-dimensional bayesian inference via the unadjusted langevin algorithm, Bernoulli, vol.25, pp.2854-2882, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01304430
Log-concave sampling: Metropolis-hastings algorithms are fast, Journal of Machine Learning Research, vol.20, pp.1-42, 2019. ,
Quasi-monte carlo finite element methods for elliptic pdes with lognormal random coefficients, Numerische Mathematik, vol.131, pp.329-368, 2015. ,
Quasi-monte carlo methods for elliptic pdes with random coefficients and applications, Journal of Computational Physics, vol.230, pp.3668-3694, 2011. ,
Monte Carlo sampling using Markov chains and their applications, Biometrika, vol.57, pp.97-109, 1970. ,
Statistical inversion theory in x-ray tomography, 2008. ,
, Statistical and computational inverse problems, vol.160, 2006.
Adaptive dimension reduction to accelerate infinite-dimensional geometric markov chain monte carlo, Journal of Computational Physics, vol.392, pp.71-95, 2019. ,
, Spectral methods for uncertainty quantification: with applications to computational fluid dynamics, 2010.
An explicit link between gaussian fields and gaussian markov random fields: the stochastic partial differential equation approach, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.73, pp.423-498, 2011. ,
Monte Carlo strategies in scientific computing, 2008. ,
Sequential monte carlo methods for dynamic systems, Journal of the American statistical association, vol.93, pp.1032-1044, 1998. ,
Dimensionality reduction and polynomial chaos acceleration of bayesian inference in inverse problems, Journal of Computational Physics, vol.228, pp.1862-1902, 2009. ,
Equation of state calculations by fast computing machines, Journal of Chemical Physics, vol.21, pp.1087-1092, 1953. ,
Low-Rank Tensor Methods for Model Order Reduction, pp.857-882, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01262403
Transport map accelerated markov chain monte carlo, SIAM/ASA Journal on Uncertainty Quantification, vol.6, pp.645-682, 2018. ,
Reduced basis approximation and a posteriori error estimation for parametrized partial differential equations, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-01722593
A computational framework for infinite-dimensional bayesian inverse problems, part ii: Stochastic newton mcmc with application to ice sheet flow inverse problems, SIAM Journal on Scientific Computing, vol.36, pp.1525-1555, 2014. ,
Ridge functions, vol.205, 2015. ,
Weak convergence and optimal scaling of random walk Metropolis algorithms, Annals of Applied Probability, vol.7, pp.110-120, 1997. ,
Optimal scaling for various metropolis-hastings algorithms, Statistical science, vol.16, pp.351-367, 2001. ,
Optimal low-rank approximations of bayesian linear inverse problems, SIAM Journal on Scientific Computing, vol.37, pp.2451-2487, 2015. ,
Inverse problems: a Bayesian perspective, Acta Numerica, vol.19, pp.451-559, 2010. ,
Inverse problem theory and methods for model parameter estimation, vol.89, 2005. ,
Gradient-based dimension reduction of multivariate vector-valued functions, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01701425
, Certified dimension reduction in nonlinear bayesian inverse problems, 2018.
URL : https://hal.archives-ouvertes.fr/hal-01834039
