Optimal control separating two microalgae species competing in a chemostat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Proceedings/Recueil Des Communications Année : 2020
In this work, we study the question of selecting in minimal-time a microalgae species of interest using the Droop model to describe the dynamics of two distinct populations competing for a limiting nutrient. This amounts to consider an optimal control problem governed by a five-dimensional affine control system in which the control is the dilution rate. Throughout this paper, the optimal control strategies allowing the strain of interest to dominate the population in minimal-time is discussed. These results are illustrated using a numerical direct optimization method (implemented in Bocop).
CDC2020_Final_Version_Walid_Olivier_Terence.pdf (617.06 Ko) Télécharger le fichier
hal-02939495 , version 1 (15-09-2020)
Walid Djema, Olivier Bernard, Térence Bayen. Optimal control separating two microalgae species competing in a chemostat. 2020, 2020 59th IEEE Conference on Decision and Control (CDC), ⟨10.1109/CDC42340.2020.9304115⟩. ⟨hal-02939495⟩
211 Consultations
213 Téléchargements
