A Kriging-based Interacting Particle Kalman Filter for the simultaneous estimation of temperature and emissivity in Infra-Red imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Temperature estimation through infrared thermography is facing the lack of knowledge of the observed material's emissivity. The derivation of the physical equations lead to an ill-posed problem. A new Kriged Interacting Particle Kalman Filter is proposed. A state space model relates the measurements to the temperature and the Kalman filter equations yield a filter tracking the temperature over time. Moreover, a particle filter associated to Kriging prediction is interacting with a bank of Kalman filters to estimate the time-varying parameters of the system. The efficiency of the algorithm is tested on a simulated sequence of infrared thermal images.
IFAC.pdf (981.89 Ko) Télécharger le fichier
hal-02940184 , version 1 (16-09-2020)
  • HAL Id : hal-02940184 , version 1
Thibaud Toullier, Jean Dumoulin, Laurent Mevel. A Kriging-based Interacting Particle Kalman Filter for the simultaneous estimation of temperature and emissivity in Infra-Red imaging. IFAC 2020 – 21st IFAC World Congress, Jul 2020, Berlin, Germany. ⟨hal-02940184⟩
62 Consultations
159 Téléchargements
