Temperature-emissivity separation for LWIR sensing using MCMC, Algorithms and Technologies for Multispectral, Hyperspectral, and Ultraspectral Imagery XXII, vol.9840, 2016. ,
Robust kriged Kalman filtering, 49th Asilomar Conference on Signals, Systems and Computers, pp.1525-1529, 2015. ,
Statistics for Spatio-Temporal Data, Wiley Series in Probability and Statistics, 2011. ,
Journel and, Ch. J.) Huijbregts. Mining Geostatistics. Mineralogical Magazine, vol.43, issue.328, pp.563-564, 1979. ,
Thermal Radiation Heat Transfer, 2010. ,
Radiative Measurements of Temperature, Thermal Measurements and Inverse Techniques, Heat Transfer, p.587104377, 2011. ,
and Bureau de recherches géologiques et minières (France) (1962), p.491866302 ,
Re)Dice Packages for Computer Experiments, Troisièmes rencontres R, 2014. ,
Spatio-Temporal Field Estimation Using Kriged Kalman Filter (KKF) with Sparsity-Enforcing Sensor Placement, Sensors, vol.18, issue.6, p.1778, 2018. ,
Correntropy based IPKF filter for parameter estimation in presence of non-stationary noise process, IFAC-PapersOnLine, vol.51, issue.24, pp.420-427, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01887557
Seismic-induced damage detection through parallel force and parameter estimation using an improved interacting Particle-Kalman filter, Mechanical Systems and Signal Processing, vol.110, p.231, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01806896
Étude et développement d'un simulateur d'échanges radiatifs dans des scènes 3D statiques et dynamiques surveillées par thermographie infrarouge, SFT 2019 -27eme congrès français de thermique, pp.1-8, 2019. ,
The Kriged Kalman Filter, TEST: An Official Journal of the Spanish Society of Statistics and Operations Research, vol.7, pp.217-282, 1998. ,
Modal parameter estimation using interacting Kalman filter. Mechanical Systems and Signal Processing, vol.47, pp.139-150, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00824108
