New interface
Conference papers
Synchronization of Perturbed Linear Systems with Data-Rate Constraints
Abstract : In this paper, we consider the synchronization of two linear systems that are subject to unknown perturbations. One of the systems is driven by a reference signal, which is unknown to the second system. Both systems can only use a one-way communication channel to exchange information. The channel is subject to data-rate constraints. The messages are generated by a smart sensor that measures the state and is capable of performing some computations. The messages are received by a controller which interprets them to apply an appropriate control input to the system. The objective is to design a sensor/controller pair, which we will refer to as a communication protocol, such that the distance between the states of both systems is bounded, and as small as possible communication rate is necessary. In this paper, a communication protocol that achieves this objective is presented together with the minimum channel rate to implement it. Simulations of the communication protocol are provided to support the theoretical work.
Document type :
Conference papers
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-02942416
Contributor : Denis Efimov Connect in order to contact the contributor
Submitted on : Thursday, September 17, 2020 - 6:25:16 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Thursday, December 3, 2020 - 10:35:50 AM
File
CDC20_Quentin.pdf
Identifiers
  • HAL Id : hal-02942416, version 1
Citation
Quentin Voortman, Denis Efimov, Alexander Yu Pogromsky, Jean-Pierre Richard, Henk Nijmeijer. Synchronization of Perturbed Linear Systems with Data-Rate Constraints. CDC 2020 - 59th IEEE Conference on Decision and Control, Dec 2020, Jeju Island / Virtual, South Korea. ⟨hal-02942416⟩
Share
Metrics
Record views
38
Files downloads
112
