Frequency-explicit a posteriori error estimates for finite element discretizations of Maxwell's equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2022
We consider residual-based {\it a posteriori} error estimators for Galerkin discretizations of time-harmonic Maxwell's equations. We focus on configurations where the frequency is high, or close to a resonance frequency, and derive reliability and efficiency estimates. In contrast to previous related works, our estimates are frequency-explicit. In particular, our key contribution is to show that even if the constants appearing in the reliability and efficiency estimates may blow up on coarse meshes, they become independent of the frequency for sufficiently refined meshes. Such results were previously known for the Helmholtz equation describing scalar wave propagation problems, and we show that they naturally extend, at the price of many technicalities in the proofs, to Maxwell's equations. Our mathematical analysis is performed in the 3D case and covers conforming Nédélec discretizations of the first and second family. We also present numerical experiments in the 2D case, where Maxwell's equations are discretized with Nédélec elements of the first family. These illustrating examples perfectly fit our key theoretical findings and suggest that our estimates are sharp.
chaumontfrelet_vega_2022b.pdf (2.41 Mo) Télécharger le fichier
hal-02943386 , version 1 (19-09-2020)
hal-02943386 , version 2 (02-08-2022)
Théophile Chaumont-Frelet, Patrick Vega. Frequency-explicit a posteriori error estimates for finite element discretizations of Maxwell's equations. SIAM Journal on Numerical Analysis, 2022, 60 (4), ⟨10.1137/21M1421805⟩. ⟨hal-02943386v2⟩
259 Consultations
133 Téléchargements
