IRISA System for Entity Detection and Linking at CLEF HIPE 2020 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This note describes IRISA's system for the task of named entity processing on historical newspapers in French. Following a standard entity detection and linking pipeline, our system implements three steps to solve the named entity linking task. Named Entity Recognition (NER) is first performed to identify the entity mentions in a document based on a Conditional Random Fields classifier. Candidate entities from Wikidata are then generated for each mention found, using simple search. Finally, every mention is linked to one of its candidate entities in a so-called linking step leveraging various string metrics and the semantic structure of Wikidata to improve on the linking decisions.
paper_185_proc-1.pdf (230.56 Ko) Télécharger le fichier
hal-02943717 , version 1 (21-09-2020)
hal-02943717 , version 2 (22-09-2020)
Paternité
  • HAL Id : hal-02943717 , version 2
Cheikh Brahim El Vaigh, Guillaume Le Noé-Bienvenu, Guillaume Gravier, Pascale Sébillot. IRISA System for Entity Detection and Linking at CLEF HIPE 2020. Working Notes of CLEF 2020 - Conference and Labs of the Evaluation Forum, Sep 2020, Thessaloniki, Greece. ⟨hal-02943717v2⟩
192 Consultations
114 Téléchargements
