New interface
Conference papers
IRISA System for Entity Detection and Linking at CLEF HIPE 2020
Abstract : This note describes IRISA's system for the task of named entity processing on historical newspapers in French. Following a standard entity detection and linking pipeline, our system implements three steps to solve the named entity linking task. Named Entity Recognition (NER) is first performed to identify the entity mentions in a document based on a Conditional Random Fields classifier. Candidate entities from Wikidata are then generated for each mention found, using simple search. Finally, every mention is linked to one of its candidate entities in a so-called linking step leveraging various string metrics and the semantic structure of Wikidata to improve on the linking decisions.
Document type :
Conference papers
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-02943717
Contributor : CHEIKH BRAHIM EL VAIGH Connect in order to contact the contributor
Submitted on : Tuesday, September 22, 2020 - 11:15:33 AM
Last modification on : Saturday, August 6, 2022 - 3:32:48 AM
File
paper_185_proc-1.pdf
Identifiers
  • HAL Id : hal-02943717, version 2
Citation
Cheikh Brahim El Vaigh, Guillaume Le Noé-Bienvenu, Guillaume Gravier, Pascale Sébillot. IRISA System for Entity Detection and Linking at CLEF HIPE 2020. CEUR Workshop Proceedings, Sep 2020, Thessaloniki, Greece. ⟨hal-02943717v2⟩
Share
Metrics
Record views
174
Files downloads
83
