Decay of solutions to one dimensional nonlinear Schrödinger equations with white noise dispersion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series S Année : 2021
In this article, the asymptotic behavior of the solution to the following one dimensional Schrodinger equations with white noise dispersion idu + u(xx) o dW + vertical bar u vertical bar(p-1)udt = 0 is studied. Here the equation is written in the Stratonovich formulation, and W (t) is a standard real valued Brownian motion. After establishing the global well-posedness, theoretical proof and numerical investigations are provided showing that, for a deterministic small enough initial data in L-x(1) boolean AND H-x(1), the expectation of the L-x(infinity) norm of the solutions decay to zero at O(t(-1/4)) as t goes to +infinity, as soon as p > 7.
hal-02944262 , version 1 (21-09-2020)
Serge Dumont, Olivier Goubet, Youcef Mammeri. Decay of solutions to one dimensional nonlinear Schrödinger equations with white noise dispersion. Discrete and Continuous Dynamical Systems - Series S, 2021, 14 (8), pp.2877-2891. ⟨10.3934/dcdss.2020456⟩. ⟨hal-02944262⟩
145 Consultations
0 Téléchargements
