, National Institute of Standards and Technology (NIST), FIPS PUB 197, 2001.
Camellia: A 128-bit block cipher suitable for multiple platforms -Design and analysis, LNCS, vol.2012, pp.39-56, 2000. ,
On the boomerang uniformity of cryptographic sboxes, IACR Trans. Symm. Cryptol, vol.2018, issue.3, pp.290-310, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01944598
The rectangle attackrectangling the Serpent, LNCS, vol.2045, pp.340-357, 2001. ,
Related-key boomerang and rectangle attacks, LNCS, vol.3494, pp.507-525, 2005. ,
DLCT: A new tool for differential-linear cryptanalysis, EUROCRYPT 2019, Part I, volume 11476 of LNCS, pp.313-342, 2019. ,
Related-key cryptanalysis of the full AES-192 and AES-256, LNCS, vol.5912, pp.1-18, 2009. ,
Boomerang uniformity of popular s-box constructions, Proceedings of The Eleventh International Workshop on Coding and Cryptograph (WCC), 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02420970
Differential cryptanalysis of DES-like cryptosystems, CRYPTO'90, vol.537, pp.2-21, 1991. ,
Vectorial boolean functions for cryptography. Boolean models and methods in mathematics, computer science, and engineering, vol.134, pp.398-469, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-02060699
Codes, bent functions and permutations suitable for des-like cryptosystems, Des. Codes Cryptogr, vol.15, issue.2, pp.125-156, 1998. ,
Boomerang connectivity table: A new cryptanalysis tool, EUROCRYPT 2018, Part II, vol.10821, pp.683-714, 2018. ,
Refined probability of differential characteristics including dependency between multiple rounds, IACR Trans. Symm. Cryptol, vol.2017, issue.2, pp.203-227, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01649954
Differential Cryptanalysis and Boomerang Cryptanalysis of LBlock, Security Engineering and Intelligence Informatics -CD-ARES 2013 Workshops: MoCrySEn and SeCIHD, vol.8128, pp.1-15, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01506560
Impossible boomerang attack for block cipher structures, LNCS, vol.5824, pp.22-37, 2009. ,
, NBS FIPS PUB, vol.46, 1977.
A practical-time related-key attack on the KASUMI cryptosystem used in GSM and 3G telephony, CRYPTO 2010, vol.6223, pp.393-410, 2010. ,
SMS4 encryption algorithm for wireless networks, Cryptology ePrint Archive, 2008. ,
Block cipher cryptographic system, US Patent, vol.3, p.359, 1974. ,
Revisiting AES related-key differential attacks with constraint programming, Inf. Process. Lett, vol.139, pp.24-29, 2018. ,
The related-key rectangle attack -application to SHACAL-1, Huaxiong Wang, Josef Pieprzyk, and Vijay Varadharajan, vol.3108, pp.123-136, 2004. ,
Amplified boomerang attacks against reduced-round MARS and Serpent, LNCS, vol.1978, pp.75-93, 2000. ,
Differential forgery attack against LAC, Selected Areas in Cryptography -SAC 2015, vol.9566, pp.217-224, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01017048
Improved related-key differential attacks on reduced-round LBlock, LNCS, vol.12, pp.58-69, 2012. ,
New results about the boomerang uniformity of permutation polynomials, IEEE Trans. Information Theory, vol.65, issue.11, pp.7542-7553, 2019. ,
The return of the cryptographic boomerang, IEEE Trans. Information Theory, vol.57, issue.4, pp.2517-2521, 2011. ,
Minizinc: Towards a standard CP modelling language. In Principles and Practice of Constraint Programming -CP, LNCS, vol.4741, pp.529-543, 2007. ,
Differentially uniform mappings for cryptography, LNCS, vol.765, issue.93, pp.55-64, 1994. ,
Choco Documentation. TASC, INRIA Rennes, LINA CNRS UMR 6241, 2016. ,
TWINE : A lightweight block cipher for multiple platforms, SAC 2012, vol.7707, pp.339-354, 2013. ,
, Boomerang connectivity table revisited. IACR Trans. Symm. Cryptol, vol.2019, issue.1, pp.118-141, 2019.
The 128-bit blockcipher CLEFIA (extended abstract), LNCS, vol.4593, pp.181-195, 2007. ,
The boomerang attack, LNCS, vol.1636, pp.156-170, 1999. ,
Boomerang switch in multiple rounds, IACR Trans. Symm. Cryptol, vol.2019, issue.1, pp.142-169, 2019. ,
LBlock: A lightweight block cipher, LNCS, vol.11, pp.327-344, 2011. ,
On the construction of block ciphers provably secure and not relying on any unproved hypotheses, LNCS, vol.89, pp.461-480, 1990. ,
LAC: a lightweight authenticated encryption cipher, 2014. ,
