, Turbulent kinetic energy budget at three locations, vol.9
Turbulent flow past a surface-mounted two-dimensional rib, Journal of Fluids Engineering, vol.116, pp.238-246, 1994. ,
Particle image velocimetry, 2011. ,
Energy dissipation estimates in oscillating grid setup: LDV and PIV measurements, Environmental Fluid Mechanics, vol.7, pp.143-158, 2007. ,
Turbulent kinetic energy budget in the boundary layer developing over an urban-like rough wall using PIV, Physics of Fluids, vol.29, p.85113, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01634889
Turbulence over urbantype roughness: Deductions from wind-tunnel measurements, Boundary layer Meteo, vol.118, pp.109-131, 2006. ,
Wallwake flows downstream of a sphere placed on a plane rough wall, J. Hydraulic Eng, vol.137, issue.10, pp.1173-1189, 2011. ,
Correlation between synchronised power and flow measurements, a way to characterize turbulent effects on a marine current turbine, Proceedings of the 11th European Wave and Tidal Energy Conference, 2015. ,
Énergies marines hydrolienne et houlomotrice, 2010. ,
Use of angle resolved PIV to estimate local specific energy dissipation rates for up-and downpumping pitched blade agitators in a stirred tank, Chemical Engineering Science, vol.64, pp.126-143, 2009. ,
, Turbulence. 2nd Edition, 1975.
URL : https://hal.archives-ouvertes.fr/insu-01344576
Étude expérimentale de la turbulence dans les zones a forts courants et de son impact sur les hydroliennes, 2019. ,
An experimental study of influence of bathymetry on turbulence at a tidal stream site, Proceedings of the 12th European Wave and Tidal Energy Conference, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02140512
Experimental study of the wall-mounted cylinder wake effects on a tidal turbine behaviour compared to free stream turbulence, Proceedings of the 13th European Wave and Tidal Energy Conference, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02570118
Experimental investigation of the turbulent wake past real seabed elements for velocity variations characterization in the water column, International Journal of Heat and Fluid Flow, vol.78, p.108426, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02285983
Experimental study of coherent flow structures past a wall-mounted square cylinder, Ocean Engineering, vol.182, pp.137-146, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02140518
Investigation of turbulent flows and instabilities in a stirred vessel using particle image velocimetry, 2005. ,
The local structure of turbulence in incompressible viscous fluid for very large Reynolds number, Doklady Akademii Nauk, vol.30, pp.9-13, 1941. ,
Measurement of the turbulent kinetic energy budget of a planar wake flow in pressure gradients, Experiments in Fluids, vol.37, pp.469-482, 2004. ,
A parallel digital processor system for particle image velocimetry, Measurement Science Technology, vol.4, pp.619-626, 1993. ,
Modélisation de la turbulence engendrée par la morphologie du fond marin dans le Raz-Blanchard: Approche locale LBM-LES, 2019. ,
The merging of kelvinhelmholtz vortices into large coherent flow structures in a high Reynolds number flow past a wall-mounted square cylinder, Ocean Engineering, vol.204, pp.0-00, 2020. ,
Simulated electrical power potential harnessed by marine current turbine arrays in the Alderney Race, Renewable Energy, vol.30, pp.1713-1731, 2005. ,
The role of coherent structures in subgridscale energy transfer within the log layer of wall turbulence, Physics of Fluids, p.18, 2006. ,
Impact of environmental turbulence on the performance and loadings of a tidal stream turbine. Flow, Turbulence and Combustion, p.102, 2018. ,
Piv investigation of flow behind surface mounted detached square cylinder, Journal of Fluids Engineering, vol.131, pp.1-16, 2009. ,
Turbulent structures and budgets behind permeable ribs, Experimental Thermal and Fluid Science, vol.32, pp.1011-1033, 2008. ,
Turbulent flows, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00712179
The terms of turbulent kinetic energy budget within random arrays of emergent cylinders, Water resources research, vol.50, pp.4131-4148, 2014. ,
Turbulent kinetic energy dissipation rate estimate from piv velocity vector fields, Experiments in Fluids, vol.29, pp.300-307, 2000. ,
Flow relaxation past a transverse square rib in pressure gradients, AIAA Journal, issue.7, p.46, 2008. ,
A large eddy PIV method for turbulence dissipation rate estimation, Chemical Engineering Science, vol.55, pp.4423-4434, 2000. ,
General circulation experiments with the primitive equations, Monthly Weather Review, vol.91, pp.99-164, 1963. ,
A first course in turbulence, 1972. ,
Universal outlier detection for PIV data, Experiments in Fluids, vol.39, pp.1096-1100, 2005. ,
Dissipation rate estimation in the turbulent boundary layer using high-speed planar particle image velocimetry, Experiments in Fluids, vol.60, p.18, 2019. ,
