A note on the lifted Miller-Tucker-Zemlin subtour elimination constraints for routing problems with time windows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Operations Research Letters Année : 2020
We propose lifted versions of the Miller-Tucker-Zemlin subtour elimination constraints for routing problems with time windows (TW). The constraints are valid for problems such as the travelling salesman problem with TW, the vehicle routing problem with TW, the generalized travelling salesman problem with TW, and the general vehicle routing problem with TW. They are corrected versions of the constraints proposed by Desrochers and Laporte (1991).
MTZ_VRPTW.pdf (183.2 Ko) Télécharger le fichier
hal-02947086 , version 1 (23-09-2020)
Yuan Yuan, Diego Cattaruzza, Maxime Ogier, Frédéric Semet. A note on the lifted Miller-Tucker-Zemlin subtour elimination constraints for routing problems with time windows. Operations Research Letters, 2020, 48 (2), pp.167-169. ⟨10.1016/j.orl.2020.01.008⟩. ⟨hal-02947086⟩
116 Consultations
2421 Téléchargements
