Investigating Collaborative Exploration of Design Alternatives on a Wall-Sized Display - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Industrial design review is an iterative process which mainly relies on two steps involving many stakeholders: design discussion and CAD data adjustment. We investigate how a wall-sized display could be used to merge these two steps by allowing multidisciplinary collaborators to simultaneously generate and explore design alternatives. We designed Shape-Compare based on the feedback from a usability study. It enables multiple users to compute and distribute CAD data with touch interaction. To assess the benefit of the wall-sized display in such context, we ran a controlled experiment which aims to compare ShapeCompare with a visualization technique suitable for standard screens. The results show that pairs of participants performed a constraint solving task faster and used more deictic instructions with ShapeCompare. From these findings, we draw generic recommendations for collaborative exploration of alternatives.
hal_version.pdf (15.5 Mo) Télécharger le fichier
hal-02947245 , version 1 (23-09-2020)
Yujiro Okuya, Olivier Gladin, Nicolas Ladevèze, Cédric Fleury, Patrick Bourdot. Investigating Collaborative Exploration of Design Alternatives on a Wall-Sized Display. CHI 2020 - ACM Conference on Human Factors in Computing Systems, Apr 2020, Honolulu, United States. pp.1-12, ⟨10.1145/3313831.3376736⟩. ⟨hal-02947245⟩
155 Consultations
277 Téléchargements
