Provenance for the Description Logic ELHr (Extended Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This extended abstract presents our work on provenance forthe description logic ELHr published at IJCAI 20
DL2020.pdf (349.2 Ko) Télécharger le fichier
hal-02947265 , version 1 (23-09-2020)
  • HAL Id : hal-02947265 , version 1
Camille Bourgaux, Ana Ozaki, Rafael Peñaloza, Livia Predoiu. Provenance for the Description Logic ELHr (Extended Abstract). DL 2020 - 33rd International Workshop on Description Logics, Sep 2020, Rhodes / Virtual, Greece. ⟨hal-02947265⟩
35 Consultations
57 Téléchargements
