Generative and Discriminative Algorithms for Spoken Language Understanding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Spoken Language Understanding (SLU) for conversational systems (SDS) aims at extracting concept and their relations from spontaneous speech. Previous approaches to SLU have modeled concept relations as stochastic semantic networks ranging from generative approach to discriminative. As spoken dialog systems complexity increases, SLU needs to perform understanding based on a richer set of features ranging from a-priori knowledge, long dependency, dialog history, system belief, etc. This paper studies generative and discriminative approaches to modeling the sentence segmentation and concept labeling. We evaluate algorithms based on Finite State Transducers (FST) as well as discriminative algorithms based on Support Vector Machine sequence classifier based and Conditional Random Fields (CRF). We compare them in terms of concept accuracy, generalization and robustness to annotation ambiguities. We also show how non-local non-lexical features (e.g. a-priori knowledge) can be modeled with CRF which is the best performing algorithm across tasks. The evaluation is carried out on two SLU tasks of different complexity, namely ATIS and MEDIA corpora. Index Terms: spoken language understanding (SLU), conditional random fields (CRF), classifiers based sequence labeling, finite state transducers (FST).
i07_1605.pdf (106.63 Ko) Télécharger le fichier
hal-02949194 , version 1 (25-09-2020)
  • HAL Id : hal-02949194 , version 1
Christian Raymond, Giuseppe Riccardi. Generative and Discriminative Algorithms for Spoken Language Understanding. Interspeech 2007 - 8th Annual Conference of the International Speech Communication Association, Aug 2007, Anvers, Belgium. ⟨hal-02949194⟩
173 Consultations
266 Téléchargements
