Toward Speculative Loop Pipelining for High-Level Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems Année : 2020
Loop pipelining is a key optimization in modern HLS tools for synthesizing efficient hardware datap-aths. Existing techniques for automatic loop pipelining are limited by static analysis that cannot precisely analyze loops with data-dependent control-flow and/or memory accesses. We propose a technique for speculative loop pipelining that handles both control-flow and memory speculations in a unified manner. Our approach is entirely expressed at the source-level, allowing a seamless integration to development flows using HLS. Our evaluation shows significant improvement in throughput over standard loop pipelining.
Cases2020_R2.pdf (2.36 Mo) Télécharger le fichier
hal-02949516 , version 1 (25-09-2020)
Steven Derrien, Thibaut Marty, Simon Rokicki, Tomofumi Yuki. Toward Speculative Loop Pipelining for High-Level Synthesis. IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, 2020, 39 (11), pp.4229 - 4239. ⟨10.1109/TCAD.2020.3012866⟩. ⟨hal-02949516⟩
200 Consultations
493 Téléchargements
