, Algorithm 1 can be called several times on sub-intervals of n + k ? [L/10, L ? 1], since the main memory usage (the sieve array T ) is proportional to the subinterval length. We used this for n = 44, 494, and 539, with sub-intervals of length 2 · 10 12 . And by storing only even values of T, ? If memory is a bottleneck
, Algorithm 1 was implemented in the C language, using the GMP library for the large integer operations, and OpenMP for the parallel code. The locks for accesses to T use the OpenMP atomic update instruction. On a processor with 112 hyperthreaded cores, this implementation takes about 100 seconds (of wall-clock time) to find C(98) = 259110640 with L = 10 9
Pythagorean triples and triangular numbers, Fibonacci Quart, vol.17, pp.168-172, 1979. ,
Numerical investigations of Recamán's sequence, in preparation, 2020. ,
, A Course in Computational Algebraic Number Theory, 1993.
On the frequency of numbers containing prime factors of a certain relative magnitude, Ark. Mat. Astr. Fys, vol.22, pp.1-14, 1930. ,
, Smooth numbers: computational number theory and beyond, vol.44, pp.267-323, 2008.
Pythagorean triples and sums of triangular numbers, Internat. J. Mathematical Education in Science and Technology, vol.28, issue.1, pp.109-116, 1997. ,
Speeding up Integer Multiplication and Factorization, 2010. ,
URL : https://hal.archives-ouvertes.fr/tel-01748662
A Note on triangular numbers, Punjab University J. Math, vol.26, pp.75-83, 1993. ,
, A hyperelliptic smoothness test. I, Phil. Trans. Roy. Soc. London, Series A, vol.345, pp.397-408, 1993.
An Introduction to the Theory of Numbers, 1991. ,
On the representation of the integers as a difference of nonconsecutive triangular numbers, Fibonacci Quart, vol.39, pp.256-263, 2001. ,
, The On-Line Encyclopedia of Integer Sequences
On triangular numbers which are sums of two smaller triangular numbers, Wiadom. Mat, vol.7, issue.2, pp.27-28, 1963. ,
On Pythagorean triples containing a fixed integer, Fibonacci Quart, vol.46, issue.4, pp.331-340, 2008. ,
A note on Sierpi?ski's problem related to triangular numbers, Colloq. Math, vol.117, issue.2, pp.165-173, 2009. ,
On representing an integer as a sum of two triangular numbers, vol.15, pp.104-105, 1972. ,
, Mathematics Subject Classification: 11B83 (11D72, 11D85) Keywords: Number sequences, Recamán sequence, recurrences, triangular number triples
