Reflection, Refraction, and Hamiltonian Monte Carlo, Proc. 28th NeurIPS, pp.3007-3015, 2015. ,
The polynomial eigenvalue problem is well conditioned for random inputs, SIMAX, vol.40, issue.1, pp.175-193, 2019. ,
The real polynomial eigenvalue problem is well conditioned on the average, J. Foundations of Computational Math, pp.1-19, 2019. ,
The polynomial eigenvalue problem, 2005. ,
A conceptual introduction to Hamiltonian Monte Carlo, 2017. ,
A survey of computational complexity results in systems and control, Automatica, vol.36, issue.9, pp.1249-1274, 2000. ,
Effective computational geometry for curves and surfaces, 2006. ,
Random spectrahedra, SIAM J. Optimization, vol.29, issue.4, pp.2608-2624, 2019. ,
Exact Volume Computation for Polytopes: A Practical Study, Polytopes Combinatorics and Computation, DMV Seminar, pp.131-154, 2000. ,
Random walks for probabilistic robustness, Proc. CDC, vol.5, pp.5316-5321, 2004. ,
Robust convex programs: Randomized solutions and applications in control, Proc. CDC, vol.3, pp.2423-2428, 2003. ,
, Practical volume estimation by a new annealing schedule for cooling convex bodies, 2019.
Sampling the feasible sets of SDPs and volume approximation, Communications in Computer Algebra, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02572792
Vaidya walk: A sampling algorithm based on the volumetric barrier, 55th Annual Allerton Conference on Communication, Control, and Computing (Allerton), pp.1220-1227, 2017. ,
Hamiltonian Monte Carlo with boundary reflections, and application to polytope volume calculations, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01919855
Bypassing KLS: Gaussian cooling and an O * (n 3 ) volume algorithm, Proc. ACM Symposium Theory of computation (STOC), pp.539-548, 2015. ,
A practical volume algorithm, Mathematical Programming Computation, vol.8, 2016. ,
A randomized cutting plane method with probabilistic geometric convergence, SIAM J. Optimization, vol.20, pp.3185-3207, 2010. ,
Perturbation theory for homogeneous polynomial eigenvalue problems, Linear algebra & Appl, vol.358, issue.1-3, pp.71-94, 2003. ,
A random polynomial-time algorithm for approximating the volume of convex bodies, J. ACM, vol.38, issue.1, pp.1-17, 1991. ,
Practical polytope volume approximation, Prelim. version: Proc. SoCG, vol.44, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01897272
, of I.M.A. volumes in Math & its Applications, vol.151, 2010.
Separation bounds for polynomial systems, J. Symbolic Computation, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01105276
Random sampling: Billiard walk algorithm, European J. Operational Research, vol.238, 2012. ,
Eigen v3, 2010. ,
Approximate volume and integration for basic semialgebraic sets, SIAM review, vol.51, issue.4, pp.722-743, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00297384
Simulated annealing for convex optimization, Math. Oper. Res, vol.31, issue.2, pp.253-266, 2006. ,
On the complexity of computing determinants, Computational complexity, vol.13, issue.3-4, pp.91-130, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02102099
Randomized algorithms for robust control analysis and synthesis have polynomial complexity, Proceedings of 35th IEEE Conference on Decision and Control, vol.3, pp.3470-3475, 1996. ,
Convergence rates of moment-sum-of-squares hierarchies for volume approximation of semialgebraic sets, Optimization Letters, vol.12, issue.3, pp.435-442, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01415327
Computing the volume of compact semi-algebraic sets, Proc. ISSAC, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02110556
Spherical Hamiltonian Monte Carlo for Constrained Target Distributions, JMLR workshop and Conf procs, vol.32, pp.629-637, 2014. ,
On the complexity of the Lickteig-Roy subresultant algorithm, J. Symbolic Computation, vol.92, pp.243-268, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01450869
Algorithmic theory of odes and sampling from well-conditioned logconcave densities, 2018. ,
Convergence Rate of Riemannian Hamiltonian Monte Carlo and Faster Polytope Volume Computation, Proc. ACM Symp. Theory of Computation (STOC), 2018. ,
Sylvester-habicht sequences and fast cauchy index computation, J. Symbolic Computation, vol.31, issue.3, pp.315-341, 2001. ,
Random walks and an O * (n 5 ) volume algorithm for convex bodies, Random Structures & Algorithms, vol.11, pp.1-50, 1997. ,
Simulated annealing in convex bodies and an O * (n 4 ) volume algorithm, Proc. IEEE Symp. Foundation of Comp. Science (FOCS), pp.650-659, 2003. ,
Fast algorithms for logconcave functions: Sampling, rounding, integration and optimization, Proc. IEEE Symp. Foundation of Comp. Science (FOCS), pp.57-68, 2006. ,
Matrix Differential Calculus with Applications in Statistics and Econometrics (Revised Edition), 1999. ,
Faster polytope rounding, sampling, and volume computation via a sub-linear ball walk, Proc. IEEE Symp. Foundation of Comp. Science (FOCS), pp.1338-1357, 2019. ,
Exact Hamiltonian Monte Carlo for Truncated Multivariate Gaussians, J. Computational & Graphical Statistics, vol.23, issue.2, pp.518-542, 2014. ,
Univariate polynomials: nearly optimal algorithms for numerical factorization and root-finding, J. Symbolic Computation, vol.33, issue.5, pp.701-733, 2002. ,
Nearly optimal refinement of real roots of a univariate polynomial, J. Symbolic Computation, vol.74, pp.181-204, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00960896
Billiard walk -a new sampling algorithm for control and optimization. IFAC Proceedings Volumes, vol.47, pp.6123-6128, 2014. ,
The D-decomposition technique for linear matrix inequalities. Automation and Remote Control, vol.67, pp.1847-1861, 2006. ,
Some geometric results in semidefinite programming, J. Global Optimization, vol.7, 1999. ,
A monte carlo approach to the analysis of control system robustness, Automatica, vol.29, issue.1, pp.229-236, 1993. ,
The fundamental theorem of algebra in terms of computational complexity, 1982. ,
Efficient monte carlo procedures for generating points uniformly distributed over bounded regions, Operations Research, vol.32, issue.6, pp.1296-1308, 1984. ,
A header-only C++ library for large scale eigenvalue problems ,
Geometry and billiards. Student mathematical library, 2005. ,
Randomized algorithms for analysis and control of uncertain systems: with applications, 2012. ,
Backward error and condition of polynomial eigenvalue problems, Linear Algebra & Appl, vol.309, issue.1, pp.339-361, 2000. ,
Numerical linear algebra, 1997. ,
Geometric random walks: A survey, Combinatorial & Computational Geometry, vol.52, 2005. ,
Implementation and evaluation of sdpa 6.0, Optimization Methods & Software, vol.18, issue.4, pp.491-505, 2003. ,
