Endocytosis as a stabilizing mechanism for tissue homeostasis, Proceedings of the National Academy of Sciences, vol.115, issue.8, pp.1926-1935, 2018. ,
Synchronization of diffusivelyconnected nonlinear systems: results based on contractions with respect to general norms, IEEE Trans. Network Sci. Eng, vol.1, issue.2, pp.91-106, 2014. ,
Some remarks on spatial uniformity of solutions of reaction-diffusion PDEs, Nonlinear Anal, vol.147, pp.125-144, 2016. ,
Boundary control of coupled reaction-diffusion processes with constant parameters, Automatica J. IFAC, vol.54, pp.80-90, 2015. ,
Efficient parameter search for qualitative models of regulatory networks using symbolic model checking, Bioinformatics, vol.26, issue.18, pp.603-610, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00482569
Exact control of genetic networks in a qualitative framework: the bistable switch example, Automatica J. IFAC, vol.47, issue.6, pp.1105-1112, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00507040
Coupling and synchronization of piecewise linear genetic regulatory systems, CDC 2019 -58th IEEE Conference on Decision and Control, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02386348
Cell synchronization by double thymidine block, Bio-protocol, vol.8, issue.17, 2018. ,
Dihedral groups, Lecture notes ,
Modeling cell-cell communication for immune systems across space and time, Current Opinion in Systems Biology, vol.18, pp.44-52, 2019. ,
Modeling and simulation of genetic regulatory systems: a literature review, J. Comput. Biol, vol.9, issue.1, pp.67-103, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072606
Convergence, consensus and synchronization of complex networks via contraction theory, Complex systems and networks, pp.313-339, 2016. ,
On synchronization and cross-talk in parallel networks, Second International Conference on Dynamics of Continuous, Discrete and Impulsive Systems, vol.10, pp.287-300, 2001. ,
Control design for sustained oscillation in a two-gene regulatory network, Journal of Mathematical Biology, vol.62, issue.4, pp.453-478, 2011. ,
A mathematical framework for the control of piecewise-affine models of gene networks, Automatica J. IFAC, vol.44, issue.9, pp.2326-2332, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00831803
Periodic solutions of piecewise affine gene network models with non uniform decay rates: The case of a negative feedback loop, Acta Biotheoretica, vol.57, issue.4, pp.429-455, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00831799
Phase locking and multiple oscillating attractors for the coupled mammalian clock and cell cycle, Proceedings of the National Academy of Sciences, vol.111, issue.27, pp.9828-9833, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01421054
Construction of a genetic toggle switch in escherichia coli, Nature, vol.403, pp.339-381, 2000. ,
Symbolic reachable set computation of piecewise affine hybrid automata and its application to biological modelling: Delta-notch protein signalling, IEE Proceedings -Systems Biology, vol.1, issue.1, pp.170-183, 2004. ,
Prediction of limit cycles in mathematical models of biological oscillations, Papers presented at the Society for Mathematical Biology Meeting, vol.40, pp.27-44, 1976. ,
Rigid patterns of synchrony for equilibria and periodic cycles in network dynamics, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.26, p.94803, 2016. ,
Monotone dynamical systems, Handbook of differential equations: ordinary differential equations, vol.2, pp.239-357, 2006. ,
Rna synthetic biology, Nature biotechnology, vol.24, issue.5, pp.545-554, 2006. ,
Programmable cells: Interfacing natural and engineered gene networks, Proceedings of the National Academy of Sciences, vol.101, issue.22, pp.8414-8419, 2004. ,
Clusters in nonsmooth oscillator networks, Phys. Rev. E, vol.97, p.32213, 2018. ,
Towards a theory for diffusive coupling functions allowing persistent synchronization, Nonlinearity, vol.27, issue.3, pp.501-525, 2014. ,
Phase portrait control for 1D monostable and bistable reaction-diffusion equations, Nonlinearity, vol.32, issue.3, pp.884-909, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01800382
Qualitative simulation of the carbon starvation response in escherichia coli, Biosystems, vol.84, issue.2, pp.124-152, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00171698
Synchronization of interconnected systems with applications to biochemical networks: an input-output approach, IEEE Trans. Automat. Control, vol.55, issue.6, pp.1367-1379, 2010. ,
Synchronization in networks of identical linear systems, Automatica, vol.45, issue.11, pp.2557-2562, 2009. ,
Monotone Dynamical Systems: An Introduction to the Theory of Competitive and Cooperative Systems: An Introduction to the Theory of Competitive and Cooperative Systems. Number 41, 2008. ,
Complete characterization of the stability of cluster synchronization in complex dynamical networks, Science Advances, vol.2, issue.4, 2016. ,
