New interface
Conference papers
Computing 3D Periodic Triangulations
Manuel Caroli 1 Monique Teillaud 1
1 GEOMETRICA - Geometric computing
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Saclay - Ile de France
Abstract : This work is motivated by the need for software computing 3D periodic triangulations in numerous domains including astronomy, material engineering, biomedical computing, fluid dynamics etc. We design an algorithmic test to check whether a partition of the 3D flat torus into tetrahedra forms a triangulation (which subsumes that it is a simplicial complex). We propose an incremental algorithm that computes the Delaunay triangulation of a set of points in the 3D flat torus without duplicating any point, whenever possible; our algorithmic test detects when such a duplication can be avoided, which is usually possible in practical situations. Even in cases where point duplication is necessary, our algorithm always computes a triangulation that is homeomorpic to the flat torus. To the best of our knowledge, this is the first algorithm of this kind whose output is provably correct. The implementation will be released in CGAL.
Document type :
Conference papers
Complete list of metadata
Cited literature [39 references]  Display  Hide  Download
https://hal.inria.fr/hal-02954152
Contributor : Monique Teillaud Connect in order to contact the contributor
Submitted on : Wednesday, September 30, 2020 - 6:51:22 PM
Last modification on : Saturday, June 25, 2022 - 9:15:22 PM
Long-term archiving on: : Monday, January 4, 2021 - 8:50:03 AM
periodic_triang.pdf
Identifiers
Collections
Citation
Manuel Caroli, Monique Teillaud. Computing 3D Periodic Triangulations. ESA Symposia - 17th European Symposium on Algorithms, Sep 2009, Copenhagen, Denmark. pp.59-70, ⟨10.1007/978-3-642-04128-0_6⟩. ⟨hal-02954152⟩
Share
Metrics
Record views
23
Files downloads
102
