Simultaneous stabilization of Port-Hamiltonian systems subject to actuation saturation and input delay, Int. J. Autom. Comput, 2015. ,
Simultaneous stabilization technique for damping controller design in power systems, Intelligent Automation & Soft Computing, vol.12, pp.41-49, 2006. ,
Simultaneous stabilization for uncertain descriptor systems with input saturation, International Journal of Robust and Nonlinear Control, vol.22, pp.1938-1951, 2012. ,
it Simultaneous stabilization for a collection of uncertain time-delay systems using sliding-mode output feedback control, International Journal of Control, 2018. ,
Time-Varying Stabilizers for Stochastic Systems with no Unforced Dynamics, Asian J. Control, vol.20, issue.5, pp.1713-1719, 2018. ,
A universal formula for the stabilization of control stochastic differential equations, Stochastic Analysis and Applications, vol.11, pp.155-162, 1993. ,
Stochastic Modeling and Control of Bioreactors, IFAC-PapersOnLine, vol.50, pp.12611-12616, 2017. ,
Simultaneous stabilization of full state information Linear Time-Invariant systems, Asian J. Control, vol.14, pp.1382-1386, 2012. ,
Global state feedback stabilization of stochastic high-order nonlinear systems with high-order and low-order nonlinearities, International Journal of Systems Science, 2016. ,
Simultaneous stabilization of linear systems, Control Theory and Applications, vol.28, pp.58-73, 2011. ,
Universal Feedback Controllers and Inverse Optimality for Nonlinear Stochastic Systems, J. Dyn. Sys., Meas., Control, vol.142, 2020. ,
Exponential Stability of Stochastic Differential Equations with Impulse Effects at Random Times, Asian J. Control, vol.22, issue.2, pp.779-787, 2020. ,
Simultaneous stabilization for a collection of stochastic nonlinear systems based on CLFs, International Conference on Control, Automation and Diagnosis (ICCAD'19), 2019. ,
Simultaneous Stabilization of Single-Input Nonlinear Systems With Bounded Controls ,
URL : https://hal.archives-ouvertes.fr/hal-02943170
Stochastic differential equations and diffusion processes, 1981. ,
Global Output Feedback Stabilization for Stochastic Nonlinear Systems with Function Control Coefficients, Asian J. Control, vol.18, issue.4, pp.1189-1199, 2016. ,
Nonlinear systems, 2002. ,
, Stochastic Stability of Differential Equations, 1980.
Introduction to stochastic calculus with applications, 2005. ,
Conservatism reduction in simultaneous output feedback stabilisation of linear systems, IET Control Theory & Applications, vol.10, pp.2243-2250, 2016. ,
Converse theorems for stochastic Lyapunov functions, SIAM J.Control Optim, vol.5, pp.228-233, 1967. ,
Option Valuation Under Stochastic Volatility II, 2009. ,
Global stability and stabilization of more general stochastic nonlinear systems, Journal of Mathematical Analysis and Application, vol.413, pp.841-855, 2014. ,
Some Open Problems on Simultaneous Stabilization of Linear Systems, Journal of Systems Science and Complexity, vol.29, pp.289-299, 2016. ,
A universal formula for stabilization with bounded controls, Systems & control letters, vol.16, pp.393-397, 1991. ,
, Stochastic Differential Equations and Their Applications, 1997.
Euler-Maruyama approximations in mean-reverting stochastic volatility model under regime-switching, Journal of Applied Mathematics and Stochastic Analysis, pp.1-20, 2006. ,
A note on weak solutions to stochastic differential equations, Kybernetika, vol.54, pp.888-907, 2018. ,
Continuous feedback stabilization for a class of affine stochastic systems ,
A universal construction of Artstein's theorem on nonlinear stabilization, Systems & control letters, vol.13, pp.117-123, 1989. ,
Simultaneous stabilization of a set of nonlinear port-controlled Hamiltonian systems, Automatica, vol.43, pp.403-415, 2007. ,
Simultaneous stabilization for a collection of single-input nonlinear systems, IEEE Trans. Autom. Control, vol.50, pp.328-337, 2005. ,
Simultaneous stabilization for a collection of nonlinear control systems in canonical form, Asian Journal of Control, vol.11, pp.295-301, 2009. ,
Sufficient conditions for simultaneous stabilization of three linear systems within the framework of nest algebras, Journal of the Franklin Institute, vol.351, pp.5310-5325, 2014. ,
Simultaneous stabilization of a collection of singleinput nonlinear systems based on CLFs, Asian Journal of Control, vol.13, pp.582-589, 2011. ,
Finite-Time Stabilization of Stochastic High-Order Nonlinear Systems, Asian J. Control, vol.18, issue.6, pp.2244-2255, 2016. ,
Nonsmooth Stabilization of a Class of Markovian Jump Stochastic Nonlinear Systems with Parametric and Dynamic Uncertainties, Asian J. Control, vol.21, issue.1, pp.617-631, 2019. ,
Simultaneous H 2 /H ? stabilization for chemical reaction systems based on orthogonal complement space, Int. J. Automation and Computing, vol.13, pp.19-30, 2016. ,
Network-based simultaneous H ? stabilization for chemical reaction systems with multiple packet dropouts, Int. J. Cont. Aut. and Syst, vol.15, pp.104-112, 2017. ,
