Counting phylogenetic networks of level 1 and 2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Biology Année : 2020
Phylogenetic networks generalize phylogenetic trees, and have been introduced in order to describe evolution in the case of transfer of genetic material between coexisting species. There are many classes of phylogenetic networks, which can all be modeled as families of graphs with labeled leaves. In this paper, we focus on rooted and unrooted level-k networks and provide enumeration formulas (exact and asymptotic) for rooted and unrooted level-1 and level-2 phylogenetic networks with a given number of leaves. We also prove that the distribution of some parameters of these networks (such as their number of cycles) are asymptotically normally distributed. These results are obtained by first providing a recursive description (also called combinatorial specification) of our networks, and by next applying classical methods of enumerative, symbolic and analytic combinatorics.
hal-02955527 , version 1 (02-10-2020)
Mathilde Bouvel, Philippe Gambette, Marefatollah Mansouri. Counting phylogenetic networks of level 1 and 2. Journal of Mathematical Biology, 2020, 81, pp.1357-1395. ⟨10.1007/s00285-020-01543-5⟩. ⟨hal-02955527⟩
163 Consultations
0 Téléchargements
