Viral quasispecies evolution, Microbiology and Molecular Biology Reviews, vol.76, issue.2, pp.159-216, 2012. ,
RNA virus error catastrophe: direct molecular test by using ribavirin, Proceedings of the National Academy of Sciences, vol.98, issue.12, pp.6895-6900, 2001. ,
Quasispecies diversity determines pathogenesis through cooperative interactions in a viral population, Nature, vol.439, pp.344-348, 2006. ,
Why are RNA virus mutation rates so damn high?, PLOS Biology, vol.16, issue.8, pp.1-6, 2018. ,
Critical assessment of metagenome interpretation -a benchmark of metagenomics software, Nature Methods, vol.14, pp.1063-1071, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01633525
Genome graphs and the evolution of genome inference, Genome Research, vol.27, issue.5, pp.665-676, 2017. ,
Variation graph toolkit improves read mapping by representing genetic variation in the reference, Nature Biotechnology, vol.36, pp.875-879, 2018. ,
Interior-point polynomial algorithms in convex programming, vol.13, 1994. ,
Metagenomic abundance estimation and diagnostic testing on species level, Nucleic Acids Research, vol.41, issue.1, p.10, 2012. ,
Abundance estimation and differential testing on strain level in metagenomics data, Bioinformatics, vol.33, issue.14, pp.124-132, 2017. ,
Near-optimal probabilistic RNA-seq quantification, Nature Biotechnology, vol.34, pp.525-527, 2016. ,
HIV haplotype inference using a propagating dirichlet process mixture model, IEEE Transactions on Computational Biology and Bioinformatics, vol.11, issue.1, pp.182-191, 2014. ,
ShoRAH: estimating the genetic diversity of a mixed sample from next-generation sequencing data, BMC Bioinformatics, vol.12, issue.1, p.119, 2011. ,
QuRe: software for viral quasispecies reconstruction from next-generation sequencing data, Bioinformatics, vol.28, issue.1, pp.132-133, 2012. ,
aBayesQR: A bayesian method for reconstruction of viral populations characterized by low diversity, Journal of Computational Biology, vol.25, issue.7, pp.637-648, 2018. ,
De novo assembly of viral quasispecies using overlap graphs, Genome Research, vol.27, issue.5, pp.835-848, 2017. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01693168
Full-length de novo viral quasispecies assembly through variation graph construction, Bioinformatics, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01964730
Qsdpr: Viral quasispecies reconstruction via correlation clustering, Genomics, vol.110, issue.6, pp.375-381, 2018. ,
De novo haplotype reconstruction in viral quasispecies using paired-end read guided path finding, Bioinformatics, vol.34, issue.17, pp.2927-2935, 2018. ,
CliqueSNV: Scalable reconstruction of intra-host viral populations from NGS reads, 2018. ,
A novel min-cost flow method for estimating transcript expression with RNA-seq, BMC Bioinformatics, vol.14, issue.5, p.15, 2013. ,
On the complexity of minimum path cover with subpath constraints for multi-assembly, BMC Bioinformatics, vol.15, issue.9, p.5, 2014. ,
Efficient RNA isoform identification and quantification from RNA-seq data with network flows, Bioinformatics, vol.30, issue.17, pp.2447-2455, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00803134
StringTie enables improved reconstruction of a transcriptome from RNA-seq reads, Nature Biotechnology, vol.33, pp.290-295, 2015. ,
Transcript assembly and quantification by RNA-seq reveals unannotated transcripts and isoform switching during cell differentiation, Nature Biotechnology, vol.28, pp.511-515, 2010. ,
SPAdes: A new genome assembly algorithm and its applications to single-cell sequencing, Journal of Computational Biology, vol.19, issue.5, pp.455-477, 2012. ,
metaSPAdes: a new versatile metagenomic assembler, Genome Research, vol.27, issue.5, pp.824-834, 2017. ,
Ray meta: scalable de novo metagenome assembly and profiling, Genome Biology, vol.13, issue.12, p.122, 2012. ,
Meta-IDBA: a de novo assembler for metagenomic data, Bioinformatics, vol.27, issue.13, pp.94-101, 2012. ,
MEGAHIT: an ultra-fast single-node solution for large and complex metagenomics assembly via succinct de Bruijn graph, Bioinformatics, vol.31, issue.10, pp.1674-1676, 2015. ,
De novo assembly of highly diverse viral populations, BMC Genomics, vol.13, issue.1, p.475, 2012. ,
QUAST: quality assessment tool for genome assemblies, Bioinformatics, vol.29, issue.8, pp.1072-1075, 2013. ,
An illumina paired-end and mate-pair short read simulator, 2014. ,
Full-length haplotype reconstruction to infer the structure of heterogeneous virus populations, Nucleic Acids Research, vol.42, p.115, 2014. ,
High resolution sequencing of hepatitis C virus reveals limited intra-hepatic compartmentalization in end-stage liver disease, Journal of Hepatology, vol.66, issue.1, pp.28-38, 2017. ,
Computational pan-genomics: status, promises and challenges, Briefings in Bioinformatics, vol.19, issue.1, pp.118-135, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01390478
, Network Flows: Theory, Algorithms, and Applications, 1993.
Microbiome, metagenomics, and high-dimensional compositional data analysis, Annual Review of Statistics and Its Application, vol.2, issue.1, pp.73-94, 2015. ,
A survey of best practices for RNA-seq data analysis, Genome Biology, vol.17, issue.13, 2016. ,
Theory and a heuristic for the minimum path flow decomposition problem, IEEE/ACM Transactions on Computational Biology and Bioinformatics, issue.99, pp.1-1, 2017. ,
A practical fpt algorithm for flow decomposition and, 2017. ,
Simple bounds and greedy algorithms for decomposing a flow into a minimal set of paths, European Journal of Operational Research, vol.185, issue.3, pp.1390-1401, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00125839
Tour merging via branch-decomposition, INFORMS Journal on Computing, vol.15, issue.3, pp.233-248, 2003. ,
A solution merging heuristic for the steiner problem in graphs using tree decompositions, pp.391-402, 2015. ,
