PHYSALIS (Physics-Driven Cosparse Analysis) - Archive ouverte HAL Access content directly
Software Year :
(1) , (1) , (1, 2) , (1)
1
2
PHYSALIS (Physics-Driven Cosparse Analysis) is a software package for reproducible research. It contains the Matlab routines allowing to reproduce the main experimental results on joint source localization and estimation of the Ph.D. thesis of Srdan Kitic, notably of the article Srđan Kitić, Laurent Albera, Nancy Bertin, Rémi Gribonval. Physics-driven inverse problems made tractable with cosparse regularization. IEEE Transactions on Signal Processing, Institute of Electrical and Electronics Engineers, 2016, 64 (2), pp.335-348
556 View
32 Download
Share
