PHYSALIS (Physics-Driven Cosparse Analysis) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Logiciel Année : 2015
PHYSALIS (Physics-Driven Cosparse Analysis) is a software package for reproducible research. It contains the Matlab routines allowing to reproduce the main experimental results on joint source localization and estimation of the Ph.D. thesis of Srdan Kitic, notably of the article Srđan Kitić, Laurent Albera, Nancy Bertin, Rémi Gribonval. Physics-driven inverse problems made tractable with cosparse regularization. IEEE Transactions on Signal Processing, Institute of Electrical and Electronics Engineers, 2016, 64 (2), pp.335-348
891 Consultations
36 Téléchargements
