Edge-disjoint spanning trees of finite graphs, Journal of the London Mathematical Society, issue.1, pp.445-450, 1961. ,
Update on k-truss decomposition on gpu, 2019 IEEE High Performance Extreme Computing Conference (HPEC), pp.1-7, 2019. ,
Finding and counting given length cycles, Algorithmica, vol.17, issue.3, pp.209-223, 1997. ,
Large scale networks fingerprinting and visualization using the k-core decomposition, Advances in neural information processing systems, pp.41-50, 2006. ,
Static graph challenge on GPU, 2017 IEEE High Performance Extreme Computing Conference (HPEC), pp.1-8, 2017. ,
Bubing: Massive crawling for the masses, TWEB, vol.12, issue.2, 2018. ,
The webgraph framework i: Compression techniques, 13th International Conference on World Wide Web, WWW '04, pp.595-602, 2004. ,
Distributed algorithms for ktruss decomposition, 2014 IEEE International Conference on, pp.471-480, 2014. ,
Arboricity and subgraph listing algorithms, SIAM Journal on Computing, vol.14, issue.1, pp.210-223, 1985. ,
Trusses: Cohesive subgraphs for social network analysis, National Security Agency Technical Report, vol.16, 2008. ,
Discovering $k$-trusses in large-scale networks, 2018 IEEE High Performance Extreme Computing Conference, pp.1-6, 2018. ,
Finding all maximal cliques in very large social networks, 9th International Conference on Extending Database Technology, EDBT 2016, pp.173-184, 2016. ,
Graph algorithms via suitesparse: Graphblas: triangle counting and k-truss, 2018 IEEE High Performance extreme Computing Conference (HPEC), pp.1-6, 2018. ,
Effective community search for large attributed graphs, Proc. VLDB Endow, vol.9, pp.1233-1244, 2016. ,
Computing the degeneracy of large graphs, LATIN 2014: Theoretical Informatics -11th Latin American Symposium, pp.250-260, 2014. ,
Corecluster: A degeneracy based graph clustering framework, AAAI, vol.14, pp.44-50, 2014. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01083536
Quickly finding a truss in a haystack, High Performance Extreme Computing Conference (HPEC), 2017 IEEE, pp.1-7, 2017. ,
Querying ktruss community in large and dynamic graphs, ACM SIGMOD international conference on Management of data, pp.1311-1322, 2014. ,
Parallel k-truss decomposition on multicore systems, High Performance Extreme Computing Conference (HPEC), 2017 IEEE, pp.1-7, 2017. ,
Influential community search in large networks, Proc. VLDB Endow, vol.8, pp.509-520, 2015. ,
Linear algebraic formulation of edgecentric k-truss algorithms with adjacency matrices, 2018 IEEE High Performance extreme Computing Conference (HPEC), pp.1-7, 2018. ,
Collaborative (CPU + GPU) algorithms for triangle counting and truss decomposition, 2018 IEEE High Performance Extreme Computing Conference, HPEC, pp.1-7, 2018. ,
org: Raising the bar on graph analytic performance, 2017. ,
Triangle counting for scale-free graphs at scale in distributed memory, 2017 IEEE High Performance Extreme Computing Conference (HPEC), pp.1-4, 2017. ,
K-truss decomposition for scale-free graphs at scale in distributed memory, 2018 IEEE High Performance extreme Computing Conference (HPEC), pp.1-6, 2018. ,
Spread it good, spread it fast: Identification of influential nodes in social networks, 24th International Conference on World Wide Web, pp.101-102, 2015. ,
Graphchallenge.org: Raising the bar on graph analytic performance, IEEE High Performance Extreme Computing Conference, HPEC, pp.1-7, 2018. ,
Truss decomposition on shared-memory parallel systems, 2017 IEEE High Performance Extreme Computing Conference (HPEC), pp.1-6, 2017. ,
An efficient branch-and-bound algorithm for finding a maximum clique with computational experiments, Journal of Global Optimization, vol.37, issue.1, pp.95-111, 2007. ,
Parallel triangle counting and k-truss identification using graph-centric methods, 2017 IEEE High Performance Extreme Computing Conference (HPEC), pp.1-7, 2017. ,
Truss decomposition in massive networks, VLDB Endowment, vol.5, issue.9, pp.812-823, 2012. ,
Two efficient local search algorithms for maximum weight clique problem, AAAI, pp.805-811, 2016. ,
Enumerating k-vertex connected components in large graphs, 2017. ,
Subcubic equivalences between path, matrix and triangle problems, Foundations of Computer Science (FOCS), 2010 51st Annual IEEE Symposium on, pp.645-654, 2010. ,
Fast linear algebra-based triangle counting with KokkosKernels, 2017 IEEE High Performance Extreme Computing Conference (HPEC), pp.1-7, 2017. ,
K-truss decomposition of large networks on a single consumer-grade machine, IEEE/ACM International Conference on Advances in Social Networks Analysis and Mining (ASONAM), vol.00, pp.873-880, 2018. ,
