Decentralized spectrum learning for radio collision mitigation in ultra-dense IoT networks: LoRaWAN case study and experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Telecommunications - annales des télécommunications Année : 2020
This paper describes the theoretical principles and experimental results of reinforcement learning algorithms embedded into IoT devices (Internet of Things), in order to tackle the problem of radio collision mitigation in ISM unlicensed bands. Multi-armed bandit (MAB) learning algorithms are used here to improve both the IoT network capability to support the expected massive number of objects and the energetic autonomy of the IoT devices. We first illustrate the efficiency of the proposed approach in a proof-of-concept, based on USRP software radio platforms operating on real radio signals. It shows how collisions with other RF signals are diminished for IoT devices that use MAB learning. Then we describe the first implementation of such algorithms on LoRa devices operating in a real LoRaWAN network at 868 MHz. We named this solution IoTligent. IoTligent does not add neither processing overhead, so it can be run into the IoT devices, nor network overhead, so that it requires no change to LoRaWAN protocol. Real-life experiments done in a real LoRa network show that IoTligent devices' battery life can be extended by a factor of 2, in the scenarios we faced during our experiment. Finally we submit IoTligent devices to very constrained conditions that are expected in the future with the growing number of IoT devices, by generating an artificial IoT massive radio traffic in anechoic chamber. We show that IoTligent devices can cope with spectrum scarcity that will occur at that time in unlicensed bands.
Moy2020_Article_DecentralizedSpectrumLearningF.pdf (2.17 Mo) Télécharger le fichier
hal-02956350 , version 1 (02-10-2020)
Paternité
Christophe Moy, Lilian Besson, Guillaume Delbarre, Laurent Toutain. Decentralized spectrum learning for radio collision mitigation in ultra-dense IoT networks: LoRaWAN case study and experiments. Annals of Telecommunications - annales des télécommunications, 2020, 75 (11-12), pp.711-727. ⟨10.1007/s12243-020-00795-y⟩. ⟨hal-02956350⟩
136 Consultations
96 Téléchargements
