Squeal analysis based on the effect and determination of the most influential contacts between the different components of an automotive brake system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Mechanical Sciences Année : 2019
paper_Denimal_et_al_HAL.pdf (11.05 Mo) Télécharger le fichier
hal-02957511 , version 1 (11-06-2021)
Enora Denimal, Jean-Jacques Sinou, S. Nacivet, L. Nechak. Squeal analysis based on the effect and determination of the most influential contacts between the different components of an automotive brake system. International Journal of Mechanical Sciences, 2019, 151, pp.192-213. ⟨10.1016/j.ijmecsci.2018.10.054⟩. ⟨hal-02957511⟩
41 Consultations
31 Téléchargements
