Strong Connectivity in Directed Graphs under Failures, with Applications * - Archive ouverte HAL Access content directly
Journal Articles SIAM Journal on Computing Year : 2017
In this paper, we investigate some basic connectivity problems in directed graphs (digraphs). Let G be a digraph with m edges and n vertices, and let G \ e (resp., G \ v) be the digraph obtained after deleting edge e (resp., vertex v) from G. As a first result, we show how to compute in O(m + n) worst-case time: • The total number of strongly connected components in G \ e (resp., G \ v), for all edges e (resp., for all vertices v) in G. • The size of the largest and of the smallest strongly connected components in G \ e (resp., G \ v), for all edges e (resp., for all vertices v) in G. Let G be strongly connected. We say that edge e (resp., vertex v) separates two vertices x and y, if x and y are no longer strongly connected in G \ e (resp., G \ v). As a second set of results, we show how to build in O(m + n) time O(n)-space data structures that can answer in optimal time the following basic connectivity queries on digraphs: • Report in O(n) worst-case time all the strongly connected components of G \ e (resp., G \ v), for a query edge e (resp., vertex v). • Test whether an edge or a vertex separates two query vertices in O(1) worst-case time. • Report all edges (resp., vertices) that separate two query vertices in optimal worst-case time, i.e., in time O(k), where k is the number of separating edges (resp., separating vertices). (For k = 0, the time is O(1)). All our bounds are tight and are obtained with a common algorithmic framework, based on a novel compact representation of the decompositions induced by the 1-connectivity (i.e., 1-edge and 1-vertex) cuts in digraphs, which might be of independent interest. With the help of our data structures we can design efficient algorithms for several other connectivity problems on digraphs and we can also obtain in linear time a strongly connected spanning subgraph of G with O(n) edges that maintains the 1-connectivity cuts of G and the decompositions induced by those cuts.
1511.02913.pdf (2.92 Mo) Télécharger le fichier
Dates and versions
hal-02957607 , version 1 (05-10-2020)
Identifiers
Cite
Loukas Georgiadis, Giuseppe F Italiano, Nikos Parotsidis. Strong Connectivity in Directed Graphs under Failures, with Applications *. SIAM Journal on Computing, 2017, 49 (5), pp.1880 - 1899. ⟨10.1137/19M1258530⟩. ⟨hal-02957607⟩
Collections
INRIA INRIA2
27 View
210 Download
Share
