, XONN: XNOR-based Oblivious Deep Neural Network Inference, USENIX Security, 2019.
, Deep Learning with Differential Privacy, pp.308-318, 2016.
An Analysis of Deep Neural Network Models for Practical Applications, 2016. ,
The Secret Sharer: Evaluating and Testing Unintended Memorization in Neural Networks, USENIX Security, pp.267-284, 2019. ,
EIE: Efficient Inference Engine on Compressed Deep Neural Network, 2016. ,
Deep Compression: Compressing Deep Neural Network with Pruning, Trained Quantization and Huffman Coding, ICLR, 2016. ,
, DSD: Dense-Sparse-Dense Training for Deep Neural Networks. ICLR, 2017.
Learning Both Weights and Connections for Efficient Neural Networks, NIPS, pp.1135-1143, 2015. ,
, LOGAN: Membership Inference Attacks Against Generative Models. PETS, vol.1, pp.133-152, 2019.
Distilling the Knowledge in a Neural Network, NIPS Deep Learning and Representation Learning Workshop, 2015. ,
Computing's energy problem (and what we can do about it), ISSCC, pp.10-14, 2014. ,
Ran El-Yaniv, and Yoshua Bengio, NIPS, pp.4107-4115, 2016. ,
Quantized Neural Networks: Training Neural Networks with Low Precision Weights and Activations, J. Mach. Learn. Res, vol.18, pp.6869-6898, 2017. ,
SqueezeNet: AlexNet-level accuracy with 50x fewer parameters and <1MB model size, 2016. ,
MemGuard: Defending against Black-Box Membership Inference Attacks via Adversarial Examples, CCS, 2019. ,
, Ternary Weight Networks, 2017.
Exploiting unintended feature leakage in collaborative learning, SP, 2019. ,
Machine Learning with Membership Privacy using Adversarial Regularization, CCS, pp.634-646, 2018. ,
Comprehensive Privacy Analysis of Deep Learning: Stand-alone and Federated Learning under Passive and Active White-box Inference Attacks, SP, 2019. ,
, XNOR-Net: ImageNet Classification Using Binary Convolutional Neural Networks, 2016.
, White-box vs Black-box: Bayes Optimal Strategies for Membership Inference (PMLR), vol.97, pp.5558-5567, 2019.
ML-Leaks: Model and Data Independent Membership Inference Attacks and Defenses on, Machine Learning Models. NDSS, 2018. ,
, MobileNetV2: Inverted Residuals and Linear Bottlenecks. In CVPR, pp.4510-4520, 2018.
, Reconciling Utility and Membership Privacy via Knowledge Distillation, 2019.
Reconciling Utility and Membership Privacy via Knowledge Distillation, 2019. ,
Membership inference attacks against machine learning models, SP, 2017. ,
Machine Learning Models That Remember Too Much, CCS, p.587601, 2017. ,
Systematic Evaluation of Privacy Risks of, Machine Learning Models, 2020. ,
Designing Hardware for Machine Learning: The Important Role Played by Circuit Designers, pp.46-54, 2017. ,
Efficient Processing of Deep Neural Networks: A Tutorial and Survey, Proc. IEEE, pp.2295-2329, 2017. ,
How to Train a Compact Binary Neural Network with High Accuracy?, 2017. ,
, Magnus Jahre, and Kees A. Vissers. 2017. FINN: A Framework for Fast, Scalable Binarized Neural Network Inference. In FPGA
Designing Energy-Efficient Convolutional Neural Networks using Energy-Aware Pruning, 2017. ,
Privacy Risk in Machine Learning: Analyzing the Connection to Overfitting, CSF, pp.268-282, 2018. ,
