A subdivision scheme for hexahedral meshes, The Visual Computer, vol.18, pp.343-356, 2002. ,
How does Agees smoothing method work, Proceedings of Army Numerical Analysis and Computers Conference, pp.79-82, 1979. ,
Iso-geometric finite element analysis based on Catmull-Clark subdivision solids, Computer Graphics Forum, vol.29, pp.1575-1584, 2010. ,
Recursively generated B-spline surfaces on arbitrary topological meshes, Computer-Aided Design, vol.10, pp.350-355, 1978. ,
A new solid subdivision scheme based on Box splines, Proceedings of the Seventh ACM Symposium on Solid Modeling and Applications, pp.226-233, 2002. ,
An interpolatory subdivision for volumetric models over simplicial complexes, Shape Modeling International, pp.143-152, 2003. ,
Constructing volumetric parameterization based on directed graph simplification of 1 polycube structure from complex shapes, Computer Methods in Applied Mechanics and Engineering, vol.351, pp.422-440, 2019. ,
Progressive interpolation based on Catmull-Clark subdivision surfaces, Computer Graphics Forum, pp.1823-1827, 2008. ,
Loop subdivision surface based progressive interpolation, Journal of Computer Science and Technology, vol.24, pp.39-46, 2009. ,
Subdivision surfaces: a new paradigm for thin-shell finite-element analysis, International Journal for Numerical Methods in Engineering, vol.47, pp.2039-2072, 2000. ,
Weighted progressive interpolation of Loop subdivision surfaces, Computer-Aided Design, vol.44, pp.424-431, 2012. ,
A unified interpolatory subdivision scheme for quadrilateral meshes, ACM Transactions on Graphics, p.23, 2013. ,
A simple method for interpolating meshes of arbitrary topology by Catmull-Clark surfaces, The Visual Computer, vol.26, pp.137-146, 2010. ,
A butterfly subdivision scheme for surface interpolation with tension control, ACM Transactions on Graphics (TOG), vol.9, pp.160-169, 1990. ,
Efficient, fair interpolation using Catmull-Clark surfaces, Proceedings of the 20th Annual Conference on Computer Graphics and Interactive Techniques, ACM, pp.35-44, 1993. ,
Interpolatory subdivision on open quadrilateral nets with arbitrary topology, Computer Graphics Forum, pp.409-420, 1996. ,
Integrating CAD with Abaqus: a practical isogeometric analysis software platform for industrial applications, Computers & Mathematics with Applications, vol.74, pp.1648-1660, 2017. ,
Hybrid non-uniform recursive subdivision with improved convergence rates, Computer Methods in Applied Mechanics and Engineering, vol.352, pp.606-624, 2019. ,
Survey on geometric iterative methods and their applications, Computer-Aided Design, vol.95, pp.40-51, 2018. ,
Quality guaranteed all-hex mesh generation by a constrained volume iterative fitting algorithm, Computer-Aided Design, vol.67, pp.107-117, 2015. ,
Volumetric T-spline construction using Boolean operations, Engineering with Computers, vol.30, pp.425-439, 2014. ,
Free-form deformations with lattices of arbitrary topology, Proceedings of the 23rd Annual Conference on Computer Graphics and Interactive Techniques, ACM, pp.181-188, 1996. ,
A unified subdivision scheme for polygonal modeling, Computer Graphics Forum, pp.471-479, 2001. ,
Volumetric untrimming: precise decomposition of trimmed trivariates into tensor products, Computer Aided Geometric Design, vol.71, pp.1-15, 2019. ,
A B-spline based framework for volumetric object modeling, Computer-Aided Design, vol.78, pp.36-47, 2016. ,
Interpolatory, solid subdivision of unstructured hexahedral meshes, The Visual Computer, vol.20, pp.418-436, 2004. ,
Subdivision volume splatting, EuroVis, Citeseer, pp.139-146, 2007. ,
Low-rank parameterization of planar domains for isogeometric analysis, Computer Aided Geometric Design, vol.63, pp.1-16, 2018. ,
Volumetric spline parameterization for isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.359, p.112769, 2020. ,
Isogeometric analysis based on extended Catmull-Clark subdivision, Computers & Mathematics with Applications, vol.71, pp.105-119, 2016. ,
A unified method for hybrid subdivision surface design using geometric partial differential equations, Computer-Aided Design, vol.46, pp.110-119, 2014. ,
The method of numeric polish in curve fitting, Acta Mathematica Sinica, vol.18, pp.173-184, 1975. ,
Exact evaluation of Catmull-Clark subdivision surfaces at arbitrary parameter values, Proceedings of the ACM SIGGRAPH Conference on Computer Graphics, vol.32, pp.395-404, 1998. ,
Trivariate solid T-spline construction from boundary triangulations with arbitrary genus topology, Computer-Aided Design, vol.45, pp.351-360, 2013. ,
Converting an unstructured quadrilateral/hexahedral mesh to a rational T-spline, Computational Mechanics, vol.50, pp.65-84, 2012. ,
Truncated hierarchical Catmull-Clark subdivision with local refinement, Computer Methods in Applied Mechanics and Engineering, vol.291, pp.1-20, 2015. ,
Truncated T-splines: fundamentals and methods, Computer Methods in Applied Mechanics and Engineering, vol.316, pp.349-372, 2017. ,
Truncated hierarchical tricubic C 0 spline construction on unstructured hexahedral meshes for isogeometric analysis applications, Computers & Mathematics with Applications, vol.74, pp.2203-2220, 2017. ,
Extended truncated hierarchical Catmull-Clark subdivision, Computer Methods in Applied Mechanics and Engineering, vol.299, pp.316-336, 2016. ,
Blended B-spline construction on unstructured quadrilateral and hexahedral meshes with optimal convergence rates in isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.341, pp.609-639, 2018. ,
Exact conversion from Bézier tetrahedra to Bézier hexahedra, Computer Aided Geometric Design, vol.62, pp.154-165, 2018. ,
Isogeometric computation reuse method for complex objects with topology-consistent volumetric parameterization, Computer-Aided Design, vol.91, pp.1-13, 2017. ,
Analysis-suitable volume parameterization of multi-block computational domain in isogeometric applications, Computer-Aided Design, vol.45, pp.395-404, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00685002
Optimal analysis-aware parameterization of computational domain in 3d isogeometric analysis, Computer-Aided Design, vol.45, pp.812-821, 2013. ,
URL : https://hal.archives-ouvertes.fr/inria-00539616
High-quality construction of analysis-suitable trivariate NURBS solids by reparameterization methods, Computational Mechanics, vol.54, pp.1303-1313, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00922544
Efficient construction of multi-block volumetric spline parameterization by discrete mask method, Journal of Computational and Applied Mathematics, vol.290, pp.589-597, 2015. ,
Patient-specific vascular NURBS modeling for isogeometric analysis of blood flow, Computer Methods in Applied Mechanics and Engineering, vol.196, pp.2943-2959, 2007. ,
Solid T-spline construction from boundary representations for genus-zero geometry, Computer Methods in Applied Mechanics and Engineering, vol.249, pp.185-197, 2012. ,
Conformal solid T-spline construction from boundary T-spline representations, Computational Mechanics, vol.51, pp.1051-1059, 2013. ,
