Discrete-time differentiators: design and comparative analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2021
This work deals with the problem of online differentiation of noisy signals. In this context, several types of differentiators including linear, sliding-mode based, adaptive, Kalman, and ALIEN differentiators are studied through mathematical analysis and numerical experiments. To resolve the drawbacks of the exact differentiators, new implicit and semi-implicit discretization schemes are proposed in this work to suppress the digital chattering caused by the wrong time-discretization of set-valued functions as well as providing some useful properties, e.g., finite-time convergence, invariant sliding-surface, exactness. A complete comparative analysis is presented in the manuscript to investigate the behavior of the discrete-time differentiators in the presence of several types of noises, including white noise, sinusoidal noise, and bell-shaped noise. Many details such as quantization effect and realistic sampling times are taken into account to provide useful information based on practical conditions. Many comments are provided to help the engineers to tune the parameters of the differentiators.
Mojallizadeh_etal_022021.pdf (5.95 Mo) Télécharger le fichier
hal-02960923 , version 1 (08-10-2020)
hal-02960923 , version 2 (05-02-2021)
Mohammad Rasool Mojallizadeh, Bernard Brogliato, Vincent Acary. Discrete-time differentiators: design and comparative analysis. International Journal of Robust and Nonlinear Control, 2021, 31 (16), pp.7679-7723. ⟨10.1002/rnc.5710⟩. ⟨hal-02960923v2⟩
344 Consultations
1410 Téléchargements
