An effective numerical strategy for retrieving all characteristic parameters of an elastic scatterer from its FFP measurements - Archive ouverte HAL Access content directly
Journal Articles Journal of Computational Physics Year : 2020
(1, 2) , (3) , (3) , (4, 5)
1
2
3
4
5
A new computational strategy is proposed for determining all elastic scatterer characteristics including the shape, the material properties (Lamé coefficients and density), and the location from the knowledge of far-field pattern (FFP) measurements. The proposed numerical approach is a multi-stage procedure in which a carefully designed regularized iterative method plays a central role. The adopted approach is critical for recognizing that the different nature and scales of the sought-after parameters as well as the frequency regime have different effects on the scattering observability. Identification results for two-dimensional elastic configurations highlight the performance of the designed solution methodology.
els_cas_templates(8).pdf (914.63 Ko) Télécharger le fichier
Dates and versions
hal-02961043 , version 1 (08-10-2020)
Identifiers
Cite
Izar Azpiroz, Hélène Barucq, Julien Diaz, Rabia Djellouli. An effective numerical strategy for retrieving all characteristic parameters of an elastic scatterer from its FFP measurements. Journal of Computational Physics, 2020, 419, ⟨10.1016/j.jcp.2020.109683⟩. ⟨hal-02961043⟩
33 View
116 Download
Share
