New interface
Conference papers
Automatic multiplanar CT reformatting from trans-axial into left ventricle short-axis view
Abstract : The short-axis view defined such that a series of slices are perpendicular to the long-axis of the left ventricle (LV) is one of the most important views in cardiovascular imaging. Raw trans-axial Computed Tomography (CT) images must be often reformatted prior to diagnostic interpretation in short-axis view. The clinical importance of this refor-matting requires the process to be accurate and reproducible. It is often performed after manual localization of landmarks on the image (e.g. LV apex, centre of the mitral valve, etc.) being slower and not fully reproducible as compared to automatic approaches. We propose a fast, automatic and reproducible method to reformat CT images from original trans-axial orientation to short-axis view. A deep learning based seg-mentation method is used to automatically segment the LV endocardium and wall, and the right ventricle epicardium. Surface meshes are then obtained from the corresponding masks and used to automatically detect the shape features needed to find the transformation that locates the cardiac chambers on their standard, mathematically defined, short-axis position. 25 datasets with available manual reformatting performed by experienced cardiac radiologists are used to show that our reformatted images are of equivalent quality.
Document type :
Conference papers
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-02961500
Contributor : Marta Nuñez-Garcia Connect in order to contact the contributor
Submitted on : Thursday, October 8, 2020 - 2:54:10 PM
Last modification on : Saturday, June 25, 2022 - 11:47:04 PM
Long-term archiving on: : Saturday, January 9, 2021 - 6:43:55 PM
File
SAX_reformat_Stacom2020_cr.pdf
Identifiers
  • HAL Id : hal-02961500, version 1
Citation
Marta Nuñez-Garcia, Nicolas Cedilnik, Shuman Jia, Maxime Sermesant, Hubert Cochet. Automatic multiplanar CT reformatting from trans-axial into left ventricle short-axis view. STACOM 2020 - 11th International Workshop on Statistical Atlases and Computational Models of the Heart, Oct 2020, Lima, Peru. p.108--116. ⟨hal-02961500⟩
Share
Metrics
Record views
119
Files downloads
458
