Preprints, Working Papers, ...
Shape sensitivity analysis in aerodynamics using an isogeometric Discontinuous Galerkin method
Abstract : The sensitivity equation method aims at estimating the derivative of the solution of partial differential equations with respect to a parameter of interest. The objective of this work is to investigate the ability of an isogeometric Discontinuous Galerkin (DG) method to evaluate accurately sensitivities with respect to shape parameters originating from Computer-Aided Design (CAD), in the context of compressible aerodynamics. The isogeometric DG method relies on Non-Uniform Rational B-Spline representations, which allow to define a high-order numerical scheme for Euler equations, fully consistent with CAD geometries. We detail how this formulation can be exploited to construct an efficient and accurate approach to evaluate shape sensitivities. A particular attention is paid to the treatment of boundary conditions for sensitivities, which are more tedious in the case of geometrical parameters. The proposed methodology is first verified on a test-case with analytical solution and then applied to a more demanding problem, that concerns the flow around an airfoil with its camber as shape parameter.
Keywords : OPAL-Meso
Complete list of metadata
Cited literature [33 references]  Display  Hide  Download
https://hal.inria.fr/hal-02962207
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Friday, October 9, 2020 - 9:16:09 AM
Last modification on : Thursday, October 21, 2021 - 3:28:18 PM
Long-term archiving on: : Sunday, January 10, 2021 - 6:14:38 PM
File
sens_shape_preprint.pdf
Identifiers
  • HAL Id : hal-02962207, version 1
Citation
Maxime Stauffert, Régis Duvigneau. Shape sensitivity analysis in aerodynamics using an isogeometric Discontinuous Galerkin method. 2020. ⟨hal-02962207v1⟩
Share
Metrics
Record views
79
Files downloads
137
