Semi-adaptive modal control of onboard electronic boards using an identification method, Smart Mater Struct, vol.17, issue.6, pp.1-8, 2008. ,
Damage reduction of on-board structures using piezoelectric components and active modal control -application to a printed circuit board, Mech Syst Signal Process, vol.24, issue.2, pp.352-364, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00466053
One dimensional theory of cracked bernoulli-euler beam, Int J Mech Sci, vol.26, pp.639-648, 1984. ,
Simplified models for the location of cracks in beam structures using measured vibration data, J Sound Vib, vol.251, issue.1, pp.13-38, 2002. ,
Crack modeling for structural health monitoring, Struct Health Monit, vol.1, issue.2, pp.139-148, 2002. ,
Vibrational response of a beam with a breathing crack, J Sound Vib, vol.225, issue.1, pp.201-208, 1999. ,
Time-frequency analysis of the free vibration response of a beam with a breathing crack, NDT & E International, vol.38, issue.1, pp.3-10, 2005. ,
Detection of structural damage through changes in frequency: A review, Eng Struct, vol.19, issue.9, pp.718-723, 1997. ,
Crack detection in beams using changes in frequencies and amplitudes of frequency response functions, J Sound Vib, vol.265, issue.1, pp.1-22, 2003. ,
A method for the localization of damage in a cfrp plate using damping, Mech Syst Signal Process, vol.23, issue.6, pp.1846-1854, 2009. ,
On the significance of antiresonance frequencies in experimental structural analysis, J Sound Vib, vol.219, issue.3, pp.379-394, 1999. ,
The use of antiresonances for crack detection in beams, J Sound Vib, vol.276, issue.1-2, pp.195-214, 2004. ,
A review of vibration-based structural health monitoring with special emphasis on composite materials, Shock Vib Dig, vol.38, pp.295-324, 2006. ,
Identification of an open crack in a beam using an a posteriori error estimator of the frequency response functions with noisy measurements, Eur J Mech A Solids, vol.28, issue.1, pp.75-85, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00343592
Robust damage assessment of multiple cracks based on the frequency response function and the constitutive relation error updating method, J Sound Vib, vol.312, issue.4-5, pp.821-837, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00322909
Modal parameter identification and vibration based damage detection of a multiple cracked cantilever beam, Eng Fail Anal, vol.79, pp.154-170, 2017. ,
Detection of cracks in rotor based on the 2x and 3x super-harmonic frequency components and the crack-unbalance interactions, Commun Nonlinear Sci Numer Simul, vol.13, issue.9, pp.2024-2040, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00322889
On the use of non-linear vibrations and the anti-resonances of higher-order frequency response functions for crack detection in pipeline beam, Mech Res Commun, vol.43, pp.87-95, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00703212
Cracks detection using active modal damping and piezoelectric components, Shock Vib, vol.20, issue.4, pp.619-631, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00840749
Direct calculation of modal parameters from matrix orthogonal polynomials, Mech Syst Signal Process, vol.25, issue.7, pp.2375-2387, 2011. ,
Modal control based on direct modal parameters estimation, J Vib Control, vol.24, issue.12, pp.2389-2399, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01821242
Generation and use of orthogonal polynomials for data-fitting with a digital computer, SIAM J Appl Math, vol.5, issue.2, pp.74-88, 1957. ,
Multiple input orthogonal polynomial parameterestimation, Mech Syst Signal Process, vol.1, issue.3, pp.259-272, 1987. ,
